Lathe Thread Parameters
This topic will explain the Parameters page of the Lathe Thread operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Thread operation contains the variables needed for the feature.
  • Threads Per Unit - sets the number of crests that occur for every unit of measure.
  • Thread Pitch - sets the distance between crests of the thread.
  • Thread Height - sets the distance from the minor diameter of the thread to the major diameter of the thread.
    • Override
      Select the check box to override the calculated Thread Height value and type the new value.
      Clear the check box to allow the software to calculate the Thread Height.
  • First Cut Amount - sets the amount of material removed in the first pass of the thread cutting cycle.
  • Last Cut Amount - sets the amount of material removed during the final pass of the Threading operation.
  • Number of Finish Passes - sets the number of finish passes, sometimes referred to as spring passes, the system outputs for the Thread.
Thread In-feed Angle - sets the angle of the approach into the thread. (0 degrees results in a perpendicular approach.) Select the appropriate value for the thread you are creating.
Canned Cycle Chamfer Out
These options allow you to include a chamfer at the end of the thread that is generated and has two possible selections.
Off - does not perform the Chamfer Out operation.
On - creates the chamfer out and the Number of Leads box becomes available.
Number of Leads - sets the number of threads used for the Chamfer Out (between 0.1 and 9.9).
