The Posting Manager
This topic will explain the Post
The Posting Manager
The Post
The Posting Managers Shortcut Menu
Right-clicking in the Post
- Save As - launches the Save As dialog to allow you to save the code to the desired location.
- Predator Editor - launches the NC code in Predator Editor. This option is only available if Predator Editor had been installed by previous versions of the software as this software has been phased out.
- NC Editor - launches the NC code in the NC Editor.
- Mach 3 - If a Mach 3 license is held through BobCAD-CAM, this will open the NC code directly in Mach 3.
Tip: Using Ctrl+F will allow you to use the find function in the posted code without the need for opening the code in an editor.
