Lathe Tap Parameters
This topic will explain the Parameters page of the Lathe Tap operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Tap operation contains the variables needed for the feature.
Operation Parameters
- Use Cutting Conditions
this calculates the Overall Depth and Effective Depth for this operation.
Clear the check box to manually change the values that were automatically
calculated. - Effective Depth - the
depth from theTop of Feature
(face of the feature), excluding the tool tip.
- Overall Depth - total depth from theTop of Part (face of the feature), including the tool tip. This value is output in the posted NC program.
