Lathe Thread Parameters
This topic will explain the Parameters page of the Lathe Thread operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Thread operation contains the variables needed for the feature.
- Threads
Per Unit - sets the number of crests that occur for every unit
of measure.
- Thread
Pitch - sets the distance between crests of the thread.
- Thread
Height - sets the distance from the minor diameter of the thread
to the major diameter of the thread.
- Override
Select the check box to override the calculated Thread Height value and
type the new value.
Clear the check box to allow the software to calculate the Thread Height.
- Override
- First
Cut Amount - sets the amount of material removed in the first
pass of the thread cutting cycle.
- Last
Cut Amount - sets the amount of material removed during the
final pass of the Threading operation.
- Number of Finish Passes - sets the number of finish passes, sometimes referred to as spring passes, the system outputs for the Thread.
Thread In-feed Angle- sets the angle of the approach into the thread. (0 degrees results in a perpendicular approach.) Select the appropriate value for the thread you are creating.
Canned Cycle Chamfer Out
These options allow you to include a chamfer at the end of the thread that is generated and has two possible selections.
Off
- does not perform the Chamfer Out operation.
On
- creates the chamfer out and the Number of Leads box becomes
available.
Number of Leads - sets the number of threads used for the Chamfer Out (between 0.1 and 9.9).
