Toolpath Statistics
This topic explains the Toolpath Statistics dialog, will explain where to access it, and will explain the data found in it.
Toolpath Statistics
The Toolpath Statistics dialog shows value information such as Time Data, Toolpath Extents, Toolpath Data, and Speeds and Feeds.
To view the Toolpath Statistics for a specific job:
The Toolpath Statistics Dialog
The Toolpath Statistics Tree
This is essentially a recreation of the CAM Tree in BobCAD-CAM. The main difference here, is that we are only interested in Operation data. Therefore, the only items listed are items that could house operations.
Time Data
This group will show the machining time for the various portions of the job.
Toolpath Extents
The Toolpath Extents group defines the 3 Dimensional area the toolpath is contained in. This area is relative to the Machine Setup. The data in the Toolpath Extents group, which is represented in the table below, shows the Minimum and Maximum values listed for the X, Y, and Z axes.
Axis Minimum Maximum Total
X
Y
Z
Toolpath Data
The purpose of the Toolpath Data group is to give an entity count on the toolpath itself.  This is done by analyzing the entities of the toolpath to get counts of lines moves and arcs moves and note which of each are feed moves and which are rapids. The results are listed.
# of Entities Lines Arcs Total
Feed
Rapid
Total
Speeds and Feeds
The Speeds and Feeds group will only be populated if an individual operation is selected from the Tree.
