The Bore  (3 Point) Cycle
This topic will explain the Bore (3 Point) measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and two examples.
This cycle measures a cylindrical cut extruded in the Z Axis with 3 points. This cycle can utilize the following geometry inputs:
  • An arc whose normal is parallel to the Z Axis.
  • A cylindrical surface edge whose normal is parallel to the Z Axis.
  • A cylindrical surface whose normal is parallel to the Z Axis.
Note: The probe can be made to lift between measurements to avoid obstacles The touch points move away from each other in the X and Y Axes as it is meant to measure cylindrical cut extrusions.
To access the Bore (3 Point) cycle:
  3. Click the Parameters tab.
Initial Position
  • First Angle - defines the direction of the first touch point with the X positive direction at 0°.
  • Second Angle - defines the direction of the second touch point with the X positive direction at 0°.
  • Third Angle - defines the direction of the third touch point with the X positive direction at 0°.
  • Diameter - determines the width between surface contact points.
  • Update Work Offset
Quick Steps - Bore (3 Point)
  5. Click the Parameters tab.
Example 1 - Bore (3 Point)
In this example we:
  • Select the Probe feature.
  • Select the cycle.
  • Update the cycle.
  • Utilize the Options page.
  • Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
  1. Click the Parameters tab.
  2. Select a the cylindrical surface of the bore, which has been cut along the Z Axis.
    Since our current geometry works for a Bore (4 point) cycle, that is the cycle that is currently selected for us.
Part 5) Updating the cycle
In this case, the geometry we have chosen could be interpreted as a Bore (4 point) cycle. Since this is not the cycle we intended to use, we will need to update the currently selected cycle.
  1. At the top of the Cycles section click the drop down list and select Bore (3 point) from the list.
    However, notice how the end positions are tied to the initial position.Since this is obviously not what we need, we will set that value back as it was.
The Parameters section for this cycle consists of the Z Measurement Height, the angles on which the contact points will extend, the Diameter and the Update Work Offset value. In this case we do not really need to adjust the height at which the probe will make contact. The diameter is automatic and should not need to be adjusted, and the Update Work Offset value can be used as needed.In this part, let's just take a look at adjusting some of the angles.
  1. In the Parameters section, update the Third Angle value to 170 and pressing tab.
Part 8) Utilizing the Options page
  1. Click the Options tab.
Part 9) Backploting the result
  3. Click Close.
Example 2 - Bore (3 Point) with obstacle
In this example we:
  • Select the cycle.
  • Update the cycle.
  • Update the Options section.
  • Update the Parameters.
The Options section for this cycle consists of the Radial Clearance value only. Selecting this check box will update the moves to first avoid an obstacle before dropping down. The value will allow you to set how close to the surfaces to move before dropping down to the contact depth.
Part 7) Adjusting the Initial Position
  1. In the Initial Position group, update the Z value to 0.3.75, and press Tab.
Part 8) Updating the Parameters section
  2. Click Next four times to view the probe movements.
  3. Click Close.
