The Bore on PCD Cycle
This topic will explain the Bore on PCD measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps.
This cycle measures, with 3 points each, a radial pattern of cylindrical cut extrusions which have been cut along the Z Axis. This cycle can utilize the following geometry inputs:
- All arcs of a circular pattern whose normals are all parallel to the Z Axis.
- All cylindrical surface edges of a circular pattern whose normals are all parallel to the Z Axis.
- All cylindrical surfaces of a circular pattern whose normals are all parallel to the Z Axis.
To access the Bore on PCD cycle:
- Click the Parameters tab.
Initial Position
Pitch Diameter - determines the diameter of the feature pattern to measure.
- Boss/Bore Diameter - determines the diameter of the individual features.
- First Feature Angle - determines the angle to move along to measure the first feature.
- With this check box cleared, no extra clearance will be added. - Number of Feature - determines the amount of cylindrical cuts to measure.
Quick Steps - Bore on PCD
- Click OK.
Example 1 - Bore on PCD
In this example we:
- Select the Probe feature.
- Select the cycle.
- Utilize the Options page.
- Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
The cycle can be selected with the drop down list under the Cycles section, but simply selecting the appropriate geometry will usually select the required cycle automatically.Since certain geometry could be applicable to several cycles, in some cases, the list will become much smaller.
By default the Selected Geometry list is given focus to allow you to select geometry from the graphics area. - Select one of the cylindrical surfaces which has been extruded along the Z Axis, or the edge of that surface.
The geometry is added to the Selected Geometry list, the Initial Position and Parameters section are populated, and the toolpath becomes visible. - Select another of the cylindrical surfaces.
The geometry is added to the Selected Geometry list, and toolpath appears on the selected cylinder. - Select another of the cylindrical surfaces.
The geometry is added to the Selected Geometry list, but notice toolpath doesn't appear on this cylinder.
Since this cycle is for radial patterns, and since this new geometry does not fit into a radial pattern with the other two, it is left without toolpath. - Select the last of the cylindrical surfaces.
The geometry is added to the Selected Geometry list, and toolpath appears on this, as well as the last, cylinder.
Since the third, and now fourth cylinder fit into the radial pattern of the first two, all toolpath is now added.
- In the Initial Position group, update the Z value by adding -1.00 to the end of the current value, and press Tab.
- Click the Options tab.
Tip: Using a Top View can help you ascertain the clearance of the probe easier.
- Click Close.
Example 2 - Bore on PCD
In this example we:
- Select the cycle.
Note: Notice our toolpath is currently going through the obstruction in the middle. This will be handled later in the example.
Note: Since our contact points are arranged in a radial pattern, adjusting the X,Y Initial Position will not work.However, we can adjust the Z Axis.
- Notice we seem to have cleared the surface with our probe. Click Next until contact is made with the surface.
- Click Close.
