The External Corner Cycle
This topic will explain the External Corner measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures the location of two perpendicular planar surface faces to determine the location of their intersection. This cycle can utilize the following geometry inputs:
  • Two perpendicular lines which are aligned along the X and Y Axes.
  • Two planar surface edges which are aligned along the X and Y Axes.
  • Two planar surfaces whose normals are aligned along the X and Y Axes.
To access the External Corner cycle:
  3. Click the Parameters tab.
Initial Position
  • Corner X - defines the position of the corner along the X Axis.
  • Corner Y - defines the position of the corner along the Y Axis.
  • Update Work Offset
  • X Distance - specifies the distance from the corner along the X Axis at which to move toward the surface.
    - With this check box selected, the probe will move from the initial position to the specified distance from the corner before moving toward the surface.
    - With this check box cleared, the probe will move from the initial position toward the surface.
  • Y Distance - specifies the distance from the corner along the Y Axis at which to move toward the surface.
  • X Second Distance - specifies the an additional distance from the corner along the X Axis at which to move toward the surface for another point of contact.
    - With this check box selected, an additional point of contact will be used at the specified distance from the corner.
    - With this check box cleared, an additional point of contact will not be used.
  • Y Second Distance - specifies the an additional distance from the corner along the Y Axis at which to move toward the surface for another point of contact.
Quick Steps - External Corner
  5. Click the Parameters tab.
Example - External Corner
In this example we:
  • Select the Probe feature.
  • Select the cycle.
  • Update the geometry.
  • Utilize the Options page.
  • Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
  1. Click the Parameters tab.
  2. Select the edge of the surface whose normal is parallel with the Y Axis.
    Since our current geometry works for a X Single Surface cycle, that is the cycle that is currently selected for us.
  3. Select the edge of the surface whose normal is parallel with the X Axis.
    Since our current geometry works for an External Corner cycle, that is the cycle that is currently selected for us.
Part 5) Updating the geometry
In this case, the geometry we have chosen is interpreted as an External Corner cycle. The probing feature can do quite a bit of intelligent placement of the toolpath based on the surfaces selected. When edges are the only thing used for geometry selection, not as many assumptions can be made for the intelligent placement of the toolpath. We will take a look at how the geometry selection affects the automatic placement of the created toolpath.
  1. Next to the Selected Geometry list box, click the Delete All button.
    The geometry is removed from the list, and the edges are no longer highlighted.
  2. Select the surface whose normal is along the Y Axis.
    The surface is added to the Selected Geometry list, and the toolpath updates once more showing us a X Single Surface cycle.
  3. Select the surface whose normal is along the X Axis.
    The surface is added to the Selected Geometry list, and the toolpath updates once more showing us the intended Internal Corner cycle.Notice this time, the cycle is on the correct side of the surface, as well as at the correct height.
  1. In the Initial Position group, update the X value by adding -0.25 to the end, and pressing Tab.
    The value and the toolpath update to put the initial position of the probe a quarter inch further back in X.
The Parameters section for this cycle consists of the Z Measurement Height, the Corner X and Corner Y values, and the Update Work Offset value. The Corner X and Corner Y values should not need to be adjusted since they are calculated automatically and list the position of the intended corner to be measured. For this example, we will update the Z Measurement Height.
Note: The value of the Z Measurement Height is an incremental height from the Machine Setup. In this case, our Machine Setup is at the top of the part.
  1. Update the value of the Z Measurement Height to a quarter inch below the top of the part.Since our machine setup is at the top of the part, we update the value to -0.25.
    The toolpath is updated.
The Options section for this cycle consist of a total of four options: X Distance, Y Distance, X Second Distance, and Y Second Distance. The X/Y Distance options allows you to set a distance from the intended corner at which the contact with the surface will be made. These distances will adjust the contact points without modifying the initial position. The X/Y Second Distance options allow you to create additional contact points on each of the surfaces. These additional contact points allow you to find the corner for surfaces that are not at a ninety degree angle. If both of the second distance options are not used, the corner is assumed to be ninety degrees.
  1. In the Options section, select the check box for X Distance.
    Notice the contact point updates its location along the X Axis without adjusting the initial position.
  2. In the Options section, update the X Distance value to 0.25 and press Tab.
  3. In the Options section, select the check box for X Second Distance.
    Notice a new contact point is created along the X Axis.
Note: While the value of the X,Y Distance options define the distance from the wall, notice the value of the X,Y Second Distance determines the distance between the first and second contact points.
  1. In the Options section, select the check box for Y Distance.
    Notice the contact point updates its location along the Y Axis without adjusting the initial position.
  2. In the Options section, update the Y Distance value to 0.25 and press Tab.
  3. In the Options section, select the check box for Y Second Distance.
    Notice a new contact point is created along the Y Axis. The corner is no longer assumed to be ninety degrees any longer.
  1. Click the Options tab.
  3. Click Close.
