The Web Cycle
This topic will explain the Web measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
The Web Cycle
This cycle measures the distance between two planar surface faces which are either both parallel to the X Axis, or both parallel to the Y Axis. This cycle can utilize the following geometry inputs:
- Two lines which are both parallel to the X Axis.
- Two planar surface edges which are both parallel to the X Axis.
- Two lines which are both parallel to the Y Axis.
- Two planar surface edges which are both parallel to the Y Axis.
- Two planar surfaces whose normals are both parallel to the X Axis.
- Two planar surfaces whose normals are both parallel to the Y Axis.
Note: The probe lifts between measurements and the touch points move in towards each other in the X or Y Axis as this cycle is meant to measure extrusions.
To access the Web cycle:
- Click the Parameters tab.
Initial Position
Web Width - determines the width between surface contact points.
Update Work Offset
Quick Steps - Web
- Click OK.
Example - Web
In this example we:
- Select the Probe feature.
- Select the cycle.
- Update the Options section.
- Utilize the Options page.
- Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
Note: The Web measure cycle measures the distance between two parallel surfaces that are both either parallel with the Y Axis, or the X Axis. In this case we measure two surfaces parallel with the Y Axis.
By default the Selected Geometry list is given focus to allow you to select geometry from the graphics area. - Select the edge of the planar surface whose normal is parallel with X.
Since our current geometry works for a X Single Surface cycle, that is the cycle that is currently selected for us. - Select the edge of the parallel surface.
The value and the toolpath update to put the initial position back in its original position. - In the Initial Position group, update the Y value by adding -0.5 to the end, and pressing Tab.
Note: Since our moves are in the X Axis for the surfaces we have chosen, we can adjust our Initial Position in the Y axis.
- In the Initial Position group, update the Z value to 0.675, and press Tab.
The Options section for this cycle consists of the Radial Clearance value only.This value will allow you to set how far past the surfaces to move before dropping down to the contact depth.
- Click the Options tab.
- Click Close.
