The Z Single Surface Cycle
This topic will explain the Z Single Surface measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures a planar surface face which is parallel to the XY Plane. This cycle can utilize the following geometry inputs:
  • Planar surface face whose normal is parallel to the Z Axis.
To access the Z Single Surface cycle:
  3. Click the Parameters tab.
Initial Position
  • Update Work Offset
Quick Steps - Z Single Surface
  5. Click the Parameters tab.
Example - Z Single Surface
In this example we:
  • Select the Probe feature.
  • Select the cycle.
  • Utilize the Options page.
  • Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
  1. Click the Parameters tab.
  2. Select a planar surface whose normal is parallel with Z.
  1. In the Initial Position group, update the X value by adding -0.5 to the end, and pressing Tab.
  2. In the Initial Position group, update the Y value by adding -0.5 to the end, and pressing Tab.
Note: Since our toolpath is shown on the proper side of the surface, we have no need for the Other Side button in this group.
Part 6) Utilizing the Options page
  1. Click the Options tab.
Part 7) Backploting the result
    The Backplot dialog launches.
  2. Click Next to view the probe movements.
  3. Click Close.
