Deburr 3 Axis Example 1
This tutorial explains how to create a Deburr operation and adjust that operation to output in 3 Axis.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Deburr 3AxisExample 1.sldprt
Note: In the example file provided, the Tool Crib is already equipped with the necessary tools and the stock and Machine Setup are already defined. The part is simulated using the BC_3x_Mill machine.
Part 1) Add the Feature
    The Tool Crib dialog appears.
Part 5) Surface paths
  3. Select the model.
Part 6) Tool axis control
  2. In the Tilting group, set the Machining type to 3 axis.
  3. Click Compute.
Part 7) Simulation
    Notice the operation is also trying to do the four vertical edges as well.
Part 10) Edit the feature
  1. Notice the toolpath on the corners of the part.
  2. Right-click the feature and select Edit.
  3. Click Parameters.
  4. In the Geometry input group of the Surface paths tab, click the ellipses button next to Exclude edges.
  5. Select the corner edges.
    Repeat this on the other side of the part.
  6. Click Compute.
Cuts Along Curve
