Deburr 5 Axis Example
This tutorial explains how to create a Deburr operation and adjust that operation to output in 5 Axis.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Deburr 5AxisExample.sldprt
In the example file provided, the Tool Crib is already equipped with the necessary tools and the stock and Machine Setup are already defined. The part is simulated using the BC_Hermie_C20U machine.
Part 1) Add the Feature
    The Tool Crib dialog appears.
Part 5) Surface paths
  3. Select the model.
  5. In the Geometry input group, click the ellipses button next to Exclude Edges.
    The Mill Multiaxis Wizard disappears and the Re/Select Geometry dialog opens allowing you to select edges to avoid cutting.
  6. Hover over the back edge as seen in the image below.
    With the edge highlighted, right-click and select Select Loop.
  7. Click the arrow to flip the loop selection.
  8. Select the edge along the outer diameter of the part as seen in the image below.
  9. Repeat this for the remaining edges.
  10. Rotate the part and select the edges on the back.
    With these edge selected, we will avoid the cutting the jaws holding the part in place.
  11. Click OK.
  12. In the Surface Quality group, set the Cut tolerance to 0.001.
Part 6) Link page
  1. Click the Link tab to move to that page.
  2. In the Clearance area group, set the Type to Automatic.
  3. In the Links group, set the Type to Clearance blend spline.
  4. Click Compute.
Part 7) Simulation
  2. Click in the File tab and select Options to launch the Machine Simulator Options dialog.
  3. Make sure the check box for Collision & Gouge is selected in the Popup Notifications group.
  5. Click Play to view the current operation.
    Notice the crash.
    We will need to adjust the allowable angle of tool to correct this.
  6. To close simulation, in the BobCAMmenu, click Exit Simulation.
Part 9) Edit the feature
  4. In the Tilting group, select the Tilt range check box.
  5. Set the Min.value to 25.
  6. Click Compute.
    Notice the slight tilt of the toolpath now.
Part 10) Simulation
    Notice the part is now cut without collision.
Cuts Along Curve
