Multiaxis Finishing Example 2
This tutorial explains how to create a Multiaxis Finishing feature and adjust the contact point to maintain smooth tool motion.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Multiaxis Finishing Example 2.sldprt
In the example file provided, the Tool Crib is already equipped with the necessary tools, the stock and Machine Setup are already defined, and a roughing operation has prepped the part for the finishing operations. The part is simulated using the BC_Hermie_C20U machine.
Section 1) Floor Finishing
Part 1) Add the Feature
  3. In the Multiaxis Wizard, click Mulitaxis Machining.
  2. Click Next>>to go to the Multiaxis Postingdialog.
Part 4) Select the Roughing Tool
  1. Click the Tool Crib button.
    The Tool Crib dialog appears.
  2. Select the ENDMILL FINISH tool type on the left of the dialog to show the tapered tools available in the Tool Crib.
  3. Highlight the 0.2500 Diameter tool and click OK.
    The Tool Crib dialog disappears.
  4. Click Next>>to go to the Parameters.
Part 5) Surface paths
  1. In the Pattern group, set Machining to Floor finishing.
  2. In the Sorting group, change the Cutting Method to Spiral.
  3. In the Stepover group, change the Maximum stepover to 0.02.
Part 6) Part definition
  1. Click the Part definition tab.
  2. Click the ellipses button next to Part surfaces.
    The Re/Select Geometry dialog appears.
  3. Select the check box for Select whole bodies and select the model.
  5. Click the ellipses button next to Floor surfaces.
  6. Select the bottom of the part as seen in the image below.
  7. Click OK.
  8. Click the ellipses button next to Wall surfaces.
  9. Select the walls of the part as seen in the image below.
  10. Click OK.
  11. Click Compute.
Part 7) Simulation
  2. Click Play to view the Roughing operation in simulation.
    This will allow you to ensure this operation is free of collisions.
Section 2) Wall Finishing
Part 1) Copy and Paste the feature
  1. In the CAM Tree, right-click the Feature Multiaxis and select Copy with Geometry.
  2. Right-click the feature again and select Paste.
  3. Right-click the feature that was copied and select Rename.
  4. Update the name to Floor Finish and press Enter.
Part 2) Adjust the Parameters and Compute
  1. Right-click our pasted feature and select Rename.
  2. Update the feature name to Wall Finish and press Enter.
  3. Right-click Wall Finish and select Edit.
    The Mill Multiaxis Wizard appears.
  4. Click Parameters in the tree on the left.
  5. In the Pattern group, update Machining to Wall finishing.
  6. In the Sorting group, change Cutting Method to One way.
  7. Click Compute.
    Zoom into the corner and notice the toolpath.
Part 3) Simulation
    In this case we can see the wall is finished nicely without gouges.
    But we can see wild swings in the corners while machining the fillet:
Part 4) Update the feature
  1. Right-click Wall Finish and select Edit.
  2. Click Parameters in the tree on the left.
    Notice the values in the Relative contact point height on tool profile group.
Preferred: 0.5
Minimal: 0.4
Maximal: 0.6
Preferred: 0.5
Minimal: 0.2
Maximal: 0.8
Preferred: 0.5
Minimal: 0.1
Maximal: 0.9
Preferred: 0.5
Minimal: 0
Maximal: 1
Notice the differences in toolpath depending on the Minimal and Maximal values used above.
This is due to allowable contact point used on the surface. The contact point is represented as a value between zero and one as seen below.
In this case, set the values as follows:
  1. Minimal - 0
  2. Maximal - 1
  3. Click Compute.
Part 5) Simulation
  4. In the Filemenu, click Save.
Cuts Along Curve
