Turn Mill Example
This tutorial explains how to create a Turn Mill operation and adjust some of the most commonly used settings.
If you are connected to the Internet, the part file for this example can be downloaded automatically by clicking the following link: Turn MillExample 1.sldprt
In the example file provided, the Tool Crib is already equipped with the necessary tools and the stock and Machine Setup are already defined. The part is simulated using the BC_Porting_4x_HeadTable_Rotary_Only machine.
Part 1) Add the Feature
  3. In the Multiaxis Wizard, click Turn Milling.
    The Tool Crib dialog appears.
  2. Select the Rough+2 tool and click OK.
    The Tool Crib disappears and the Rough+2 tool is now assigned.
Part 5) Surface paths
  1. In the Sorting group, set the Axial moves to Uni-directional / Positive.
    This sets tool to cut in a single direction along the axis, and forces it into a positive direction.
  2. In the Depths steps group set the Distance to 0.125.
  3. In the Stepover group set the Max.stepover to 0.250.
Part 6) Part definition
  1. Click on the Part definition tab to jump to define the geometry.
  2. Next to Part, click the drop down on Turn profile and set it to Part surface.
    This will allow us to select the solid as geometry rather than using a wireframe profile.
  3. Click the ellipses button next to Part surface.
    The Mill Multiaxis wizard disappears and the Re/Select Geometry dialog appears.
  4. Select the check box for Select whole bodies.
  5. Select the model.
  6. Click OK.
  7. Set the Stock to leave value to 0.05.
  8. Click the Axis of rotation button.
    The Rotation axis dialog appears.
  9. By default the By base point and direction option is selected.
    Set the Direction to X, and click OK.
    The dialog disappears.
  10. Click Compute.
    Notice we are machining all the way to the back of the stock.
    We will update this in the next part.
Part 7) Edit the Machining area
  1. Right click the feature in the CAM Tree and select Edit.
  2. Click Parameters in the tree on the left of the wizard.
  3. Click the Part definition tab.
  4. In the Part definition group click the Machining area button.
    The Machining area dialog appears.
  5. In the User limits group select the check box for Axial.
  6. Set the End value to 6.750.
  7. Click OK.
  8. Click Compute.
Part 8) Simulation
  3. Set the Stock to Transparent and the Workpiece to Show.
    Notice we are machining to the end of the part but do not collide with the chuck.
    This was adjusted by limiting our machining area.
  4. To close simulation, in the BobCAMmenu, click Exit Simulation.
Part 9) Edit the feature
In this part of the example we will adjust the axis offset, and the link type to see how they affect the resulting toolpath.
  1. Right-click the feature and select Edit.
  2. Click Parameters.
  3. In the Axis offset group, set the Tool diameter (%) to 10.
    This will move the tool closer inline with the axis of rotation.
Tool diameter (%) : 40 Tool diameter (%) : 10
  1. In the Non-cutting moves group, update the Ramp angle to 20.
    This adjusts the angle of the entry move.
Ramp angle : 5 Ramp angle : 20
  1. Click Compute.
Cuts Along Curve
