Pattern Repeat Overview
This topic provides an overview of the Lathe Pattern Repeat operation and provides links to the topics covering the individual pages of the operation, as well as related topics.
The Lathe Pattern Repeat Operation
The Pattern Repeat operation is designed to remove the bulk of the stock from the workpiece and is ideal for cast stock or stock that is close to the shape of the final part. Exactly how this operations are accomplished is defined in the subsequent pages of the Basic Finish operation. Each of the pages allows you to define the  variables in order to tailor the machining process to fit your needs. Use the following links to jump to the specific topics for each available Pattern Repeat operation page:
Patterns and Parameters
Rapids
Leads
Rough Overview
Basic Finish Overview
To  continue to the Pattern Repeat Patterns and Parameters topic, click Patterns and Parameters.
