Tool Library
This topic will explain the Tool Library, explain where the tool library can be accessed from, explain the options found in it, and provide links to related topics.
The Tool Library
Tip: To learn about all the functionality available in the Tool Library, see the Tool Library Functionality topic.
  • In the CAM Tree, right-click CAM Defaults, and click Tool Library.
  • In the  CAM Tree, right-click Milling Tools, Turning Tools, or Mill Turn Toolsand click Tool Library.
  • In the Tool Crib dialog box, click Add From Tool Library.
The Dialog Box Parameters
From this tool page, you can either, choose a different tool from the Tool Crib, go into the Tool Crib to add tools from your Tool Library, or enter tool specific data manually into the Tool Data Section of the page. This page will also assist in assigning Tool Numbers and Offsets, and Coolant options, as well as Speeds and Feeds.
  • Save As - opens the Save As dialog to allow you to save the library as either a .MTOOLS file, or a .XML file of a particular name. This can then be imported on another work station and merged into that library.
  • Import from File - displays the Open dialog box allowing you to navigate to and load a previously saved Tool Library file (.mtools, .ltools or .xml). This option will merge the selected tool library file into your existing library.
  • Add - automatically creates a default tool and places it in the Tool Parameters section to allow you to modify it.
  • Delete - removes the selected tool.
  • OK - confirms the changes made to the tools and closes the Tool Library dialog.
  • Cancel - closes the Tool Library dialog without saving any changes made to the library.
Note: The available Tool Parameters vary depending on the type of tool selected. Click on a tool to display the Tool Parameters for that particular tool.
Drill
ClosedCenter Drill
Tool Parameters
  • Tool Label - allows you to set, or modify, a tool name.
  • Diameter (1) - sets the diameter of the tool.
  • Sm. Dia. (2)- sets the small diameter of the tool.
  • Angle (3) - sets the angle of the area between the Small Diameter (2)  and the Diameter (1).
  • Point Angle (4) - sets the angle of the tip of the Center Drill.
  • Sm.Dia.Len. - sets the length of the Small Diameter from end of Point Angle (4) to beginning of Angle (3).
  • Tool Number - sets the number to be used in tool callout unless otherwise specified.
Tool Holder
  • Assign/Remove Tool Holder - When no tool holder has been assigned, the Holder Label will be blank, and the button will read: Assign Tool Holder. This will open The Milling Tool Holder Library to allow you to select, or create a tool holder to associate with the selected tool. Once a tool holder has been assigned, the button will read: Remove Tool Holder. This will remove the association between the tool holder and the selected tool.
Feeds and Speeds
  • Use System Feeds and Speeds
    Clear this check box to type feeds and speeds values manually.
  • Spindle Speed/RPM - is the revolutions per minute of the spindle.
  • Plunge Feedrate - is the downward feedrate. This value is linked to the Plunge Feed per Tooth.
Custom Geometry
  • Assign Tool Geometry - hides the Tool Library and opens the Tool Shape Picking dialog to allow you to select geometry from the graphics area to assign as the shape of the tool. You can learn more about assigning custom tools in the Assigning Custom Tools topic.
ClosedDrill
Tool Parameters
  • Point Angle (2) - sets the angle of the tip of the Center Drill.
  • Flute Length (3) - sets the length of the flute/cutting portion of the tool.
  • Num Flutes - specifies the number of cutting flutes for the tool.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedSpiral Tap
Tool Parameters
  • Thread-  displays the thread type and size. Click the button to launch the Thread Type dialog to allow you to change the Thread Type and Thread Size.
  • Inef. Num of Thread (1) - sets the ineffective length for tap tools using the number of threads.
  • Thread Direction - Select Right Hand or Left Hand to determine which direction the thread is tightened in.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedPoint Tap
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedHand Tap
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedRolling Tap
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedChamfer Tool
Tool Parameters
  • Sm. Dia. (2) - sets the small diameter of the tool.
  • Inef. Length - specifies the length of extension on the small diameter that is not used for cutting.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedCounterbore
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedReamer
Tool Parameters
  • Ineffective Length (2) - sets the length of the chamfer on the tip of the tool.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedBoring
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
Mill
ClosedEndmill Rough
Tool Parameters
  • Corner Radius - sets the size of the radius on the corner of the endmill.
Tool Holder
Feeds and Speeds
  • Cutting Feedrate - is the feedrate for feed moves.
Custom Geometry
ClosedEndmill Finish
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedChamfer Mill
Tool Parameters
  • Angle (2) - sets the angle of the area between the Small Diameter (3)  and the Diameter (1).
  • Sm. Dia. (3)- sets the small diameter of the tool.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedCorner-Round
When defining a corner rounding tool, the diameter must be greater than or equal to the small diameter plus twice the corner radius.
Diameter >= Small Diameter + (Corner Radius * 2)
If you enter values that do not fit this equation, an error message displays.
Tip: When defining a corner rounding tool, if the Diameter is greater than the current/default value, set the Diameter value first. This allows you to avoid receiving the error message. If the Diameter is less than the current/default value, set the Corner Radius first to avoid the error message.
Tool Parameters
  • Corner Radius (3) - sets the size of the radius on the corner of the endmill.
  • Sm.Dia.Len. (4) - sets the length of the Small Diameter from end of the Corner Radius (3) to beginning of Small Diameter (2).
  • Shaft Dimeter (5) - sets the diameter of the shaft.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedThread Mill
Tool Parameters
  • Flute Length - sets the length of the flute/cutting portion of the tool.
  • Protrusion Length (2) - sets the distance that the tool protrudes from the tool arbor when a tool holder is assigned to the tool.
  • Taper Angle (3) - sets the angle of the taper.
  • Pitch - sets the distance from one tooth to the next.
  • Thread Height (4) - is the major diameter, minus the minor diameter, divided by two.
  • Thread Angle (5) - sets the included angle between the thread flanks.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedSingle Point Thread
Tool Parameters
  • Thread Height (3) - is the major diameter, minus the minor diameter, divided by two.
  • Thread Angle (4) - sets the included angle between the thread flanks.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedV-Tool
Tool Parameters
  • Included Angle (2) - sets the angle of the tool tip.
  • Flat End Diameter - sets the diameter of the flat portion at the tip of the tool.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedTapered
Tool Parameters
  • Angle (3) - sets the angle of the taper.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedT-Cutter
Tool Parameters
  • Shaft Diameter (5) - sets the diameter of the shaft.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedDove Mill
Tool Parameters
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedLollipop
Tool Parameters
  • Shaft Diameter (3) - sets the diameter of the shaft.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedDrag Knife
Tool Parameters
  • Blade Thickness (1) - sets the width of the blade..
  • Blade Offset (2) - sets the distance between the tools center of rotation and the tip of the blade.
  • Protrusion Length (3) - sets the distance that the tool protrudes from the tool arbor when a tool holder is assigned to the tool.
Tool Holder
Feeds and Speeds
ClosedBarrel-Standard
Note: To get a more in depth look at the barrel tool type, see the Barrel Mills topic.
Tool Parameters
  • Profile Radius (3) - sets the main radius of the tool.
  • Corner Radius (4) - sets the size of the radius on the corner of the tool.
Tool Holder
Feeds and Speeds
Custom Geometry
Important: The following rules apply when creating a valid tool shape:
• Profile radius must be greater than the corner radius
• Diameter must be equal to or greater than the upper diameter
ClosedBarrel-Advanced
Note: The Advanced barrel type has several parameters that present a choice on how you would like to define the tool. To get a more in depth look at these options, see the Barrel Mills topic.
Tool Parameters
  • Flute Height by:
    • Upper Diameter - Shaft Diameter (6)
    • Length - Flute Length (2)
  • Profile Position by (Axial):
    • Distance(M) - Distance(M) (7)
    • Reference Diameter - Diameter (3)
  • Profile Position by (Radial):
    • Distance(M) - Distance(M) (8)
    • Max Diameter - Diameter (1)
  • Corner Radius:
    • None - (No additional value is added to the definition)
    • Corner - Corner Radius (5)
    • Full - (No additional value is added to the definition)
  • Diameter (1) - sets the total diameter of the widest potion of the flute.
  • Diameter (3) - sets the end diameter at the tool tip. This parameter is to be calculated as if there were no corner radius.
  • Profile Radius (4) - sets the main radius of the tool.
  • Corner Radius (5) - sets the small radius used at the corner of the tool tip.
  • Shaft Diameter (6) - sets the diameter of the shaft.
  • Distance(M) Axial (7) - sets the position of the main radius by defining the height of its center as referrenced from the tool tip.
  • Distance(M) Radial (8) - sets the position of the main radius by defining the distance of its center from the center of the tool.
Important: (8): This value will typically be negative, unless the arc and its center are on the same side of the revolved axis. See Barrel Mills.
Tool Holder
Feeds and Speeds
Custom Geometry
• Diameter must be greater than or equal to the Shaft diameter
• Diameter must be greater than the reference diameter for the barrel mill
• Profile position by (Radial): Distance (M)
          • Profile radius must be greater than the radial distance of the profile
• Profile position by (Axial): Distance (M)
          • Profile radius must be greater than the axial distance of the profile
• Profile position by (Axial): Reference diameter
          • Profile radius must be greater than the radial distance of the profile plus the reference radius
• Flute height by: Upper diameter
          • Profile radius must be greater than the radial distance of the profile plus the upper radius
• Flute height by: Length
          • Profile radius must be greater than flute length minus the axial distance of profile
ClosedBarrel-Tangent
Tool Parameters
  • Corner Radius (4) - sets the small radius used at the corner of the tool tip.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedBarrel-Lens
Tool Parameters
  • Convex Tip Radius (3) - sets the main radius of the tool tip.
Tool Holder
Feeds and Speeds
Custom Geometry
• Convex Tip Radius must be greater than, or equal to, half of the tool Diameter
ClosedBarrel-Taper
Tool Parameters
  • Taper Angle (2) - sets the angle of the tools taper.
  • Flute Length (3) - sets the length of the cutting portion of the tool.
  • Upper Radius (4) - sets the radius used between the taper and the shaft of the tool.
  • Profile Radius (5) - sets the main radius used on the taper portion of the tool.
  • Corner Radius (6) - sets the diameter of the shaft.
  • Flatness Diameter (7) - sets the width of the flat portion on the tool tip.
Tool Holder
Feeds and Speeds
Custom Geometry
• Taper angle must be greater than 0.1, and less than 89
• Profile Radius must be greater than half of the Diameter
• Corner Radius must be less than half of the Diameter
• Upper Radius must not exceed half of the Diameter
ClosedBarrel-Double
Tool Parameters
  • Lower Radius (5) - sets the radius used on the tool tip.
Tool Holder
Feeds and Speeds
Custom Geometry
ClosedBarrel-Section
Tool Parameters
  • Upper Corner Radius (4) - sets the radius used at the upper corner of the Profile Radius.
  • Lower Corner Radius (5) - sets the radius used at the lower corner of the Profile Radius.
Tool Holder
Feeds and Speeds
Custom Geometry
• Upper Corner Radius must be smaller than the Flute Length
• Lower Corner Radius must be smaller than the Flute Length
• Upper Corner Radius must be smaller than the Profile Radius
• Lower Corner Radius must be smaller than the Profile Radius
• Distance(M) Axial must be lower than the Flute Length
• Profile Radius must be greater than Distance(M) Axial
• Diameter must be greater than the Shaft Diameter
Turning
ClosedLathe Rough / Finish / Boring
Tool
  • Tool Label - adds a name to the tool, in the tool list, that allows you to easily identify the tool.
  • Tool Number - sets the assigned tool number
  • Offset Register - sets the register on the machine that stores the diameter offset values for the tool.
Insert
Note: The following Parameters section differs depending on whether the System Shape or the Custom Shape radio button is selected. Below you will find a separate Parameters section for each option.
  • System Shape - uses the following parameters to set the shape designation of the insert.
• Shape - dictates the shape designation of the insert.   • Clearance - dictates the clearance designation of the insert.
Code Letter Description Diagram Nose Angle
80° Diamond
80°
D
55° Diamond
55°
E
75° Diamond
75°
M
86° Diamond
86°
R
Round
Full Radius
S
Square
90°
T
Triangle
60°
V
35° Diamond
35°
W
Trigon
80°
Code Letter Diagram Clearance Angle
N
A
B
C
P
11°
D
15°
E
20°
F
25°
G
30°
  • Type - sets the type designation of the insert. This does not affect toolpath or output.
Corner
Tip
Center
  • Thickness - dictates the distance between the front cutting edge to the back of the insert.
  • Custom Shape - allows you to select geometry from the graphics area to define the shape of the insert.
  • Assign Tool Insert - When Custom Shape is selected, clicking the Assign Tool Insert button will hide the Tool Library and allow you to select Tool Insert geometry, as seen below, from the graphics area.
Important: When assigning insert geometry, be sure to have the reference point defined as a point, and any interior geometry drawn as a dotted line as shown. For more information, see the Assigning Lathe Tool Inserts topic.
Holder
  • Edit Tool Holder - will launch the Tool Holder Definition dialog box to allow you to specify measurements for the holder, or select geometry from the Workspace in order to define the holder.
Feeds and Speeds
  • Use Manual Feeds and Speeds
    - Default Feeds and Speeds are used.
    - Selecting this check box will give you access to the following parameters. These will allow you to set specific Feeds and Speeds for the insert. When the insert is used in the Lathe Wizard, these will be the values that are automatically entered for the tool.
ClosedLathe Groove / Cutoff
Tool
Insert
  • Tool Width - sets the width of the insert.
  • Tool Length - sets the length of the insert.
  • Side Angle - sets the side angle of the insert.
  • Tip Angle - sets the tip angle of the insert.
  • Reference Point - allows you to choose an alignment of the reference point to the insert, as seen below:
Left Corner
Tip
Right Corner
  • Nose Radius - sets the radius between the side and bottom of the insert.
Important: When assigning insert geometry, be sure to have the reference point defined as a point. For more information, see the Assigning Lathe Tool Inserts topic.
  • Tool Nose Radius - sets the radius of the tool nose.
Holder
Feeds and Speeds
    - Selecting this check box will give you access to the following parameters. These will allow you to set specific Feeds and Speeds for the insert. When the insert is used in the Lathe Wizard, the values below will be the values that are automatically entered for the tool.
  • Home Position Z - sets the Home Position in Z for the tool.
  • Home Position X - sets the Home Position in X for the tool.
  • Reverse Sign
    - With this check box cleared, the output of the X value maintains its default behavior. A move toward the center of rotation will be output as a negative move and a move away from the center of rotation a positive move.
    - With this check box selected, the output of the X value reverses. A move toward the center of rotation will be output as a negative move and a move away from the center of rotation a positive move.
ClosedLathe Thread
Shape: LayDown Shape: Top Notch
Tool
The Tool data differs slightly based on the Shape chosen.
Insert
  • Shape - sets the shape designation of the insert.
Lay Down
Top Notch
  • Tool Angle - sets the angle of the insert.
Lay Down
Top Notch
  • Tip Height - sets the tip height of the insert when the Lay Down Shape is selected.
  • Height - sets the height of the insert when the Top Notch Shape is selected.
  • Width - sets the width of the insert when the Top Notch Shape is selected.
Reference Point: Corner   Reference Point: Tip
Lay Down
Top Notch
Lay Down
Top Notch
  • IC Diameter - sets the internal circumference of the insert when the Lay Down Shape is selected.
Holder
Feeds and Speeds
  • Reverse Sign
The CAM Overview
The Mill Turn Tool Crib
The Tool Library Functionality
ClosedHole Wizards
Center Drill Parameters
Drill Operation Parameters
Chamfer Drill Parameters
Chamfer Mill Patterns
Ream Parameters
Bore Parameters
Rolling Tap Parameters
Counterbore Drill Parameters
Counterbore Mill Parameters
Tap Parameters
ClosedMill Facing Feature
Facing Patterns
Closed2 Axis Feature
Profile Rough Patterns
Profile Finish Patterns
Pocket Patterns
Facing Patterns
Engrave Parameters
Plunge Rough (2 Axis) Patterns
Corner Rounding Patterns
Closed3 Axis Feature
Closed3 Axis Standard
Z Level Rough Patterns
Z Level Finish Patterns
Planar Patterns
Spiral Patterns
Radial Patterns
Plunge Rough Patterns
Closed3 Axis Pro
Advanced Rough Patterns
Flatlands Parameters
Equidistant Patterns
Pencil Parameters
Advanced Planar Patterns
Project Curves Patterns
Advanced Z Level Finish Patterns
Closed4 Axis Rotary
4 Axis Rotary Patterns
ClosedMill Thread
Mill Thread Pattern
Closed3 Axis Wireframe
3 Axis Wireframe Parameters
ClosedV-Carve
Tapered Pocketing Parameters
V-Varve Finishing Parameters
ClosedLathe End Face and Turning
Rough Patterns
Basic Finish Patterns
Pattern Repeat Patterns
ClosedLathe Groove
Groove Rough Patterns
Groove Finish Patterns
ClosedLathe Thread
Thread Parameters
ClosedLathe Cutoff
Cutoff Parameters
ClosedLathe Stock Handling
Stock Handling Parameters
