Corner Types
This topic explains the options found in the Corner Types page of the Mill 2 Axis Wizard for the following operations:
  • Profile Rough
  • Profile Finish
  • Chamfer Mill
  • Corner Rounding
  • Drag Knife
This topic also provides links to related topics.
Corner Types
External Corners
  • Sharp - creates a sharp corner.
  • Round - creates a round corner.
  • Loop Radius - cuts a corner using a loop of a specific radius.
    • % - changes the Radius box value from a specific radius of the loop to a percentage of the tool diameter.
    • Radius - sets the size of the loop radius.
    • Min Angle - sets the minimum included angle of a corner for which the selected Corner Type is applied.
    • Max Angle - sets the maximum included angle of a corner for which the selected Corner Type is applied.
  • Loop Length - cuts a corner with a loop whose size is determined by the value entered for the length.
    • Length - sets the length of the line segment that goes beyond the corner. A loop is then created tangent to both lines.
  • Triangle - cuts a corner with a triangle whose size is determined by the value entered for the length.
    • Length - sets the length of the line segment that goes beyond the corner. These lines are then connected with another line, making a triangle.
  • Bisect Line - relieves a corner by extending a line outward from the corner and then returning to the programmed path.
    • Length - sets the length of the line segment that bisects the corner.
Internal Corners
When using the Chamfer Mill feature, this is the final page of the operation. Otherwise, clicking Next> > takes you to the next page of the Mill 2 Axis Wizard. To move to the corresponding topic, click the appropriate link below.
The Profile Rough Machine Sequence page
The Profile Finish Machine Sequence page
The Pocket Machine Sequence page
The Corner Rounding Machine Sequence page
The Drag Knife Machine Sequence page
The Chamfer Mill Machine Sequence page
