Leads
This topic explains the Leads page found in the Project Curves operation of the Mill 3 Axis Wizard.
Leads
Entry
Plunge - the tool plunges directly to the start point of the toolpath. The Lead-in and Lead-out settings become available.
Type
Single Depth - From the Feed Plane, Single Depth will move at the Plunge Feedrate to the full Depth of Cut.
Peck - From the Feed Plane, Peck will move at the Plunge Feedrate to the Peck Depth, return to the Feed Plane with a rapid move, rapid down to a point above the last depth equal to the amount of the Feed Plane being used, before continuing to the next Peck Depth amount at the Plunge Feedrate. This method will be repeated until the full Depth of Cut is reached.
Fast Peck - From the Feed Plane, Peck will move at the Plunge Feedrate to the Peck Depth, Rapid up to an amount equal the Feed Plane being used, before continuing to the next Peck Depth amount at the Plunge Feedrate. This method will be repeated until the full Depth of Cut is reached.
- Ramp - creates a linear ramp move into the stock. The ramps are automatically adjusted, based on values entered, so that collision into the model is avoided. When this option is selected the following boxes become available.
Angle of Approach - sets the angle between the ramp motion and the top of the stock.
- Spiral - creates a helical entry into the toolpath. When this option is selected the following boxes become available.
Spiral Radius - sets the distance from the center of the spiral to the edge of the spiral, when viewing the ramp from the top.
Lead-in
Vertical -
generates a plunge feed move into the feature.
Parallel -
generates a linear feed move into the feature using the Length value.
Right Angle
- generates a linear feed at a right angle to the toolpath using the
Length value.
Circular -
generates a radial move into the feature using the Radius and Angle
value.
Vertical Tangent
- plunges into an arc move that is tangent to the surface of the model
using the Radius and Angle values.
- Length
- for the Parallel and Right Angle lead options, this sets the
distance of travel before the cutter reaches the defined edge.
- Radius
- for the Circular and Vertical Tangent lead option, this sets
the radius of the arc approach into the feature.
- Angle - for the Circular and Vertical Tangent lead options, this sets the total sweep of the arc for the lead.
Lead-out
- Same As Lead-in
- Select this check box to use the Lead-in settings to automatically set the Lead-out settings.
- Clear the check box to set the Lead-out independently from the Lead-in .
Vertical -
generates a plunge feed move out of the feature.
Parallel -
generates a linear feed move out of the feature using the Length value.
Right Angle
- generates a linear feed at a right angle from the toolpath using the
Length value.
Circular -
generates a radial move out of the feature using the Radius and Angle
value.
Vertical Tangent
- move out of the feature using an arc move that is tangent to the surface of the model
with the Radius and Angle values determining the size of the arc.
- Length
distance of travel away from the feature.
- Radius
the radius of the arc move away from the feature.
