Selecting Operation Stock (Trim to Stock)
This topic will explain Trim to Stock, will describe where to find it, and provide links to related topics.
Trim to Stock
The Trim to Stock option allows you to use the current Stock Wizard stock definition, or you can select a solid model or .stl file to create the stock definition that is used to trim the toolpath in the 3 Axis Pro operations: Advanced Rough, Equidistant, Advanced Planar, Project Curves, and Advanced Z Level Finish as well as the 4 Axis Rotary operation. This topic explains how to override the Stock Wizard stock definition to assign other geometry to Trim to Stock.
After creating a CAM feature, it is added to the CAM Tree.
Mill 3 Axis Feature Example
Feature 3 Axis
           Geometry
           Boundary
       Advanced Rough
          Boundary
          Drill Tip Positions
          Operation Stock
       Gouge Check Surfaces
             Gouge Check Surfaces 1
             Gouge Check Surfaces 2
             Gouge Check Surfaces 3
             Gouge Check Surfaces 4
       Flatlands
                 Boundary
Right-click Operation Stock and click Re/Select to open the Selection Manager.
Operation Stock
Two options display in the Selection Manager:   (Solid) and (STL).
Solid Model
To select a solid model from the graphics area:
  1. Confirm (Solid)is selected, and click to select the solid you want to assign as operation stock.
  2. To confirm the selection, click (OK).
    The dialog closes and the solid is added to the operation.
  3. Compute the operation to update the toolpath and remove cutting outside of the operation stock.
Important: Be sure that the Trim to Stock check box is selected in the Parameters page of the CAM Wizard, or the operation stock isn't used in the toolpath  calculation. (This does not apply to Advanced Rough, which always uses operation stock.)
STL File
To select an .stl file:
  1. Select (STL), and select the File Unit that was used to create the .stl file.
  2. Click Browse in the STL File Name group.
    The Open dialog appears.
  3. Navigate to the file location, select the file, and click Open.
    The dialog closes and the file name now appears in the STL File Name group.
  4. Click .
  5. Compute the operation to update the toolpath and remove cutting outside of the operation stock.
The 3 Axis Advanced Rough Operation
The 3 Axis Equidistant Operation
The 3 Axis Advanced Planar Operation
The 3 Axis Advanced Z Level Finish Operation
The 3 Axis Project Curves Operation
The 4 Axis Rotary Operation
