Advanced Options for Surface Paths
The Advanced Options for Surface Paths gives extended control over Morph Between 2 Surfaces and Parallel to Surface. This option allows you to cut only in front of a selected surface.
To access the Advanced Options for Surface Paths dialog box:
- In the Surface Paths tab of the Multiaxis Wizard, in the Pattern group, click Advanced.
(This option is only available for Morph Between 2 Surfaces and Parallel to Surface.)
Note: For all ...toolpath tangent angleoptions - positive values tilt the toolpath inward (in surface normal direction) and negative values tilt the toolpath outward (opposite the surface normal direction).
Morph between 2 surfaces
- Generate Toolpath Only at Front Side
Select the check box to generate a toolpath parallel to the selected surface on its surface normal side.
Clear the check box to generate a toolpath on both sides of the selected surface.- First surface toolpath tangent angle - is added to the first toolpath cut away from the selected surface.
- Second surface toolpath tangent angle - is added to the first toolpath cut away from the selected surface.
Parallel to surface
Parallel to Surface Example
The first image is with Generate Toolpath Only at Front Side turned off.
The next image is with Generate Toolpath Only at Front Side turned on. Notice that the selected surface is virtually extended to the ends of the drive surface.
The Single Edge Toolpath Tangent Angle limits the toolpath generation. Imaging that you tilt the virtual extended surfaces with an angle.
Morph Between 2 Surfaces Example
The final images show the First Surface Toolpath Tangent Angle and Second Surface Toolpath Tangent Angle.
