Toolpath Type
The Toolpath Type page allows you to select a particular toolpath type to apply as the operation of the Multiaxis feature. The page looks similar to the following.
Toolpath Type
Strategies
Wireframe
Multiaxis Machining
Swarf Machining
Multiblade
Port Machining
Deburring
Turn Milling
Surface
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves
Parallel to Multiple Curves
Project Curves
Morph Between 2 Surfaces
Parallel to Surface
Flowline
These remaining sections explain the common parameters that are shared between many features.
  • Wireframe - is for creating multiaxis features using wireframe geometry as the drive curve and tool orientation lines.
  • Multiaxis Machining - is for roughing and finishing using solid/surface geometry.
  • Swarf Machining - uses the side of the tool or as much of the tool flute as possible. This can be used to maximize material removal, create better surface finish quality, and constant cutting conditions.
  • Multiblade - is used for parts with multiple blades such as impellers and blisks.
  • Port Machining - is used for complex tubes.
  • Deburring - is used for creating chamfers/fillets on the edges of complex parts.
  • Turn Milling - is used to apply a milling tool to spinning stock.
  • Surface - provides multiple strategies for machining solid/surface geometry. Select this option to enable the following strategies.
After selecting the Feature Type, click Next>> to go to the Posting dialog box, which is shown next.
Multiaxis Operation Tutorials
Multiaxis tutorials can be found in the Using Multiaxis Operations section of the Mill Tutorials topic.
