This topic explains the Parameters page of the Advanced Z LevelFinish operation found in the 3 Axis Wizard.
Finish
  • Depth of Cut - the distance between each pass in the Z-axis.
  • Machine Flatlands
    - Clear the check box to turn off Machine Flatlands.
    - Select the check box to turn on Machine Flatlands and create an optimized finishing path for flat areas of the model. This option adds a pass to cut the flat areas of the finishing operation.
  • Machine Vertical Walls Only
    - Clear the check box to machine the entire feature.
    - Select the check box to apply toolpath to only the vertical walls of the feature. This alters the calculation to remove the toolpath from all non-vertical areas of the feature. (When this option is selected, the Adaptive Depth of Cut becomes unavailable as it does not apply to machining vertical walls.)
  • Adaptive Depth of Cut - When this option is selected, the Machine Flatlands option becomes unavailable as the Adaptive Depth of Cut also performs the Machine Flatlands function.
    - Clear the check box to turn off Adaptive Depth of Cut.
    - Select the check box to turn on Adaptive Depth of Cut. This helps the operation to cut shallow areas of the model better by adding more passes to create a better finish.
Adaptive Depth of Cut Adaptive Depth of Cut
  •  Trim adaptive depth step passes - when this option is selected, the Adaptive Depth of Cut result is trimmed to the remove excessive cuts from areas they are not needed.
    - Clear the check box to turn off the Trim adaptive depth step passes.
    - Select the check box to turn on Trim adaptive depth step passes. This localizes the adaptive depth of cut to the areas in which it is required.
  • Trim adaptive depth step passes Trim adaptive depth step passes
    • Minimum Depth Step - determines the minimum allowed distance (in Z) between adjacent toolpath passes.
    • Maximum Stepover - determines the maximum allowed distance between toolpath passes (in XY plane). Setting this value the same as the Depth of Cut is a good starting point when experimenting.
  • Machining Tolerance - the amount of variation allowed for creating the toolpath for the feature. The accuracy of the toolpath does not exceed this range.
  • Cut Holes - extends the toolpath into any holes that may be present in the surface.
  • Ignore Holes - does not place the toolpath into any holes and treats the surface as if it is continuous and unbroken.
Depth Options
  • Top of Job
    - sets the highest Z location for toolpath as the top of stock.
    - allow you to specify the highest Z location for toolpath in this operation. Select the check box and type a value to define a plane for the top of job.
    • Pick - hides the Wizard to allow you to set the Top of Job by selecting geometry whose height, in relation to the machine setup, is at the desired value.
  • Bottom of Job
    - sets the lowest Z location for toolpath as the bottom of stock.
    - allows you to specify the lowest Z location for toolpath in this operation. Select the check box and type a value to define a plane for the bottom of job.
Note: The Bottom of Job and Top of Job values are in reference to the machining origin (Machine Setup coordinate) of the part.
Allowance
The Allowance settings are used to define the rest material, or the amount of material remaining after this operation to be removed by the next operation, in one of two ways. These options offset the model geometry to calculate the toolpath. You can use positive or negative values to leave extra material or cut deeper than the model geometry, respectively.
Offset Type
The Offset Type determines if the allowance is applied to the entire model or separately for the bottom and sides of the part. Select one of the following options and then type the allowance value in the available allowance boxes.
  • Global - applies a single allowance value to the entire model using the Allowance XYZ value.
    • Allowance XYZ - is the amount of material left on the entire model (XYZ).
  • Side and Bottom - allows you to specify separate allowances for the side (XY) and bottom (Z) of the part.
    • Side Allowance - is the amount of material left on the sides of the part (XY).
    • Bottom Allowance - is the amount of material left on the bottom of the part (Z).
  • Advanced - opens the Allowances dialog to allow you to select surfaces to assign as either Part, or Fixture, geometry items. Each of those items can then have specific allowances set.
    - With this check box cleared, only the Offset Type and Allowance above will be used for the Feature Geometry.
    - With this check box selected, the geometry and allowances set in the (Advanced) Allowances dialog will be active.
Bounds
The Trim to Stock option provides the ability to pass the stock definition to the toolpath calculation, which trims the toolpath to remove air cutting. You can assign stock geometry (.stl or solid model) to the Operation Stock item in the CAM Tree, or if you do not assign operation stock, the software uses the stock definition from the Stock Wizard. This option can be used as a 3D boundary for the operation.
Important: In order to pass a stock definition to the toolpath calculation, you must turn on Trim to Stock in the wizard as explained next. If you assign Operation Stock, but do not turn on Trim to Stock, the stock isn't used in the toolpath calculation.
  • Trim to Stock
    - Clear the check box to create the operation without trimming the toolpath to the stock.
    - Select the check box when you want the software to trim the toolpath for the operation to the stock in one of two ways. You can (1) assign a solid model or .stl file using the Operation Stock item in the CAM Tree, or (2) if you don't assign operation stock, the software automatically uses the stock from the Stock Wizard to trim the toolpath. View Selecting Operation Stock.
    Trim to Stock
