This topic explains the Options page found in the Z Level Finish operation of the Mill 3 Axis Wizard.
Limits
Cutting Extents
- All - the entire model is processed.
- Inner Most Only - only
the inner most toolpath is kept.
- Outer Most Only - only the outer most toolpath is kept.
Other
Processing
By Area - machines an entire area of the part before moving on to the next.
By Level - machines all areas of the part to the current pass depth before beginning the next pass.
Point
- Calculate From
- Tool Tip - calculates
the toolpath from the tool tip.
- Tool Center - calculates the toolpath from the center of the bottom of the tool, in the case of a straight cornered end mill, or from the center of the radius on the tool, in the case of bullnose or ball-end mills.
