Leads
This topic explains the Leads page found in the Z Level Rough operation of the Mill 3 Axis Wizard.
Leads
Entry
Plunge - the tool plunges directly to the start point of the toolpath. The Lead-in and Lead-out settings become available.
Type
Single Depth - From the Feed Plane, Single Depth will move at the Plunge Feedrate to the full Depth of Cut.
Peck - From the Feed Plane, Peck will move at the Plunge Feedrate to the Peck Depth, return to the Feed Plane with a rapid move, rapid down to a point above the last depth equal to the amount of the Feed Plane being used, before continuing to the next Peck Depth amount at the Plunge Feedrate. This method will be repeated until the full Depth of Cut is reached.
Fast Peck - From the Feed Plane, Peck will move at the Plunge Feedrate to the Peck Depth, Rapid up to an amount equal the Feed Plane being used, before continuing to the next Peck Depth amount at the Plunge Feedrate. This method will be repeated until the full Depth of Cut is reached.
Ramp - creates a linear ramp move into the stock. The ramps are automatically adjusted, based on values entered, so that collision into the model is avoided. When this option is selected the following boxes become available.
Spiral - creates a helical entry into the toolpath. When this option is selected the following boxes become available.
- Maximum Length - sets the longest distance of travel for the ramp move.
Spiral Radius - sets the distance from the center of the spiral to the edge of the spiral, when viewing the ramp from the top.
Angle of Approach - sets the angle between the ramp motion and the top of the stock.
- Spiral Tolerance - sets the interpolation accuracy of the spiral path. The smaller this value is, the smaller the segments are, and the smoother the spiral appears.
- Ramp Direction - sets the orientation of the ramp relative to the generated toolpath. A value of 0 degrees means that the ramp is parallel to the first entity in the toolpath, while a value of 90 degrees places the ramp at a right angle to the first entity in the toolpath.
