Getting to Know the User Interface (UI)
This topic will introduce you to the User Interface, provide a short explanation of each component, and provide links to the main topic of particular components where applicable.
The User Interface
There are
The Data Entry Manager handles geometry selection and feature/operation parameter input/adjustment.
The CAM Manager. This is the main element of the BobCAM user interface. The CAM Manager gives you access to the following:
The CAM Tree handles all of the machining features and operations.
The Operation Tree handles the posting order of all operations.
The Tool Tree handles the tools and which operations they are used in.
The Post Manager displays the posted NC program and also provides options for saving or editing the program.
The BobART Manager handles all image vectorization and emboss model creation for making 2D geometry or artistic 3D models (respectively) for machining.
The BobCAM Command Manager tab contains buttons for some of the most-used functions of the software. The toolbars are primarily presented for convenience and speed of use, so that you do not need to return to menu after menu to repeat functions.
The BobCAM is the menu , which provides commands to the BobCAM local or online Help system, licensing, activation, and deauthorization, as well as access to the BobCAD-CAM Support website, and the About BobCAM system information.
Tip: When entering values into the text fields, mathematics can be used. To find out more, see the Math Functions topic.
