The System Tab
This topic will explain the System tab of the Settings dialog, will explain where to access it, will explain the options found in it, and will provide links to related topics.
The System Tab
The System Tab of the Settings dialog handles system settings like directories, CAM Tree flyouts, Data Collection.
To access the Settings dialog , do one of the following:
- In the BobCAM ribbon, click
Settings. - In the command line, type BobCAM and press Enter.
You are prompted to enter the name of the BobCAM Command.- Type Settings and press Enter.
By default the Settings dialog opens on the System tab.
The System Tab
General
Directories
Each item listed shows the file path in
which the files for each item are stored. Click in the text field to input
the file location manually, or click the
button next
to each item to open the Browse for Folder dialog box. You can select
a new folder in which to store the files for the selected item. Generally
these should not be changed from the default directories.
- Data Folder - is the location for all of the BobCAD-CAM Data folders.
- CAM Features - is the location for storing the features that are saved in the CAM Tree.
Warning: Incorrect modification of these file paths can cause the system to malfunction. Do not alter these paths unless you fully understand how they work.
Data Collection
- Help improve BobCAD-CAM by sending usage statistics - BobCAD-CAM collects usage statistics from the users to help understand what features of the software are being utilized the most and aid in deciding what improvements to focus on for future releases. See https://bobcad.com/privacy/software-usage/ for more information.
Leave the check box selected so we can improve the features of the software you use the most.
Clear the check box to not share your feature usage and hope that you like what we create based on what others use most.
Browser
- Use Online Help - determines whether the local, or online help system is launched when BobCAM for Rhino Help is launched.
The online help will be launched.
The local help will be launched. - Use Default Browser - determines whether default browser is used to launch the online help and setup sheets.
The default browser is used.
The Browser Application option appears allowing you to select the .exe of the preferred browser.
User Interface Options
Theme
The Themes are what controls the appearance of the user interface. You can use these options to select between predefined combinations of graphical details, colors, and fonts.
Tree Behavior
Double-click - determines what double clicking an item in the CAD Tree, CAM Tree, or BobART Tree does. Choose between:
- Edit - launches the applicable dialog to allow you to adjust parameters in the wizard, edit geometry, set up tools, etc.
Expand/Collapse - allows you to expand and collapse items in the CAM Tree.
CAM
CAM Tree
- Enable CAM Tree Flyouts - The CAM Tree Flyouts appear as the '>>' symbols next to items in the CAM Tree. These allow you to double check some, and even edit other values by simply clicking on them in the CAM Tree.
Select the check box to show, and be able to utilize, the CAM Tree Flyouts.
Clear the check box to hide the CAM Tree Flyouts. - Auto Blank New Items - Determines the Blank/Unblank state of newly created features and their operations. By default toolpath is shown until it is hidden by the user. Using this option will reverse that and the toolpath will be hidden until the user clicks an operation in the CAM Tree, or unblanks the toolpath.
Select the check box to have the toolpath of newly created features hidden.
Clear the check box to have the toolpath of newly created features shown.
Look and Feel
- Style - allows you to adjust whether the Blank/Unblank and Post Yes/No states are accessed through the context menu only (Classic), or whether they are shown in columns in the CAM Tree and used as toggles (Extended).
| Classic | Extended |
- Status Location - allows you to adjust whether the Blank/Unblank and Post Yes/No toggles are located on the left or right side of the CAM Tree.
| Left | Right |
Tip: See the Status Style States topic to get more information.
Posting
- Font - allows you to set the font used for the posted code in the Posting Manager.
Simulation
Simulation Window - Choose between:
- Embedded Window - launches the simulation inside the graphics area of the application. The size of the simulation can only be controlled by adjusting the size of the graphics area.
- Separate Window - launches the simulation as an independent window. The size and location of the simulation can be sized, minimized and maximized as any other application.
Operation Tree
- Display Feature Name - The Operation Tree shows all jobs and their operations to more easily organize the output. This option allows you to determine whether these operations should list only the name of the individual operations themselves, or whether the feature name should appear in front of the name.
Select the check box to add "Feature Name : " before each operation name.
Clear the check box to list only the operation name.
- Apply to Default / Document - Applies the currently visible settings to the other document type. When in the Document Default tab, this will apply the same settings to the Current Document. When in the Current Document tab, this will apply the same settings to the Document Default.
Note: Only one page at a time can be applied to the other document type with the "Apply to ..." button. This ensures that the user can see the settings that are being copied to the other document type.
- OK - Closes the dialog.
- Apply - Applies the current settings.
- Cancel - Cancels any changes that have not been applied and exits the dialog.
