This operation is used to rough internal shapes using multiple vertical, or Z moves, and rapid moves above the part in X and Y. When a 2D Plunge Rough is added to the CAM tree, the system adds following items.
Geometry - Right-click this item to produce a shortcut menu with the following options.
Plunge Rough - Right-click this item to produce a shortcut menu with three options.
Edit - Allows you to modify the parameters of the Plunge Rough operation. View the 2D Plunge Rough Wizard for a detailed explanation of this dialog box and all of the parameters available for this feature.
Compute Toolpath - When selected the system calculates the toolpath.
Post Yes/No - Allows you to determine whether a feature in the CAM tree is included with the code that is posted by the system.
Rough - Right-click this item to produce a shortcut menu with two options for modifying the visibility and color of the toolpath created.
Blank - When selected, the system shows the toolpath if it is hidden or hides the toolpath if it is visible in the graphics area.
