This operation is used to rough surfaces and solids using multiple vertical, or Z moves, and rapid moves above the part in X and Y. When a 3D Plunge Rough feature is added to the CAM tree, the system adds the following items.
Plunge Rough -Right-click this item to produce a shortcut menu with the following options.
Edit - This opens the feature wizard so you can modify the settings used to create the toolpath. View the 3D Plunge Rough Wizard to learn about the options available for this feature.
Rough - Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
