The V-Carve feature type is generally used to engrave text, arcs, lines and splines in a 3-dimensional form with 3 axis tool motion, with pocketing of open spaces in the selected profiles if necessary. When a V-Carve feature is added to the CAM tree, the system adds the following items.
Feature V-Carve - Right-click this item to produce a shortcut menu with the following options.
Edit - This opens the feature wizard so you can modify the settings used to create the toolpath. View the V-Carve Wizard to learn about the options available for this feature.
V-Tool - Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
View the following illustration for an example of the toolpath produced.
After simulation, the end result looks as follows.
