This operation is used to apply a series of parallel planar cuts to surfaces, solids, or STL data. Using a series of Slice Planar operations in conjunction with the Allowance XYZ option, roughing, semi-finishing, and finishing toolpaths can be generated for the model. When a Slice Planar feature is added to the CAM tree, the system adds the following items.
Boundary - This allows you to select an area of a part in which to confine the toolpath. Right-click this item to produce a shortcut menu with the following options.
Re/Select - Select this option to enable selection mode and assign the appropriate 2D geometry as a boundary to this feature.
Remove - Select this option to remove any boundary associated with this feature.
Slice Planar - Right-click this item to produce a shortcut menu with the following options.
Edit - This opens the feature wizard so you can modify the settings used to create the toolpath. View the Slice Planar Wizard to learn about the options available for this feature.
Semi/Finish - Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
