This operation generates a radial pattern cut to surfaces, solids or STL data. Controls are provided to control angle, length and interval of the radial pattern. Using a series of Slice Radial operations in conjunction with the Allowance XYZ option, roughing, semi-finishing, and finishing toolpaths can be generated for the model. When a Slice Radial feature is added to the CAM tree, the system adds the following items.
Boundary - This allows you to select an area of a part in which to confine the toolpath. Right-click this item to produce a shortcut menu with the following options.
Re/Select - Select this option to enable selection mode and assign the appropriate 2D geometry as a boundary to this feature.
Remove - Select this option to remove any boundary associated with this feature.
Slice Radial - Right-click this item to produce a shortcut menu with the following options.
Edit -This opens the feature wizard so you can modify the settings used to create the toolpath. View the Slice Radial Wizard to learn about the options available for this feature.
Semi/Finish - Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
View the following illustration for an example of the toolpath produced.
