This operation is used to apply a continuous spiral pattern cut to surfaces, solids or STL data. The spiral can have an elliptical or round shape as defined in the operation parameters. Using a series of Slice Spiral operations in conjunction with the Allowance XYZ option, roughing, semi-finishing, and finishing toolpaths can be generated for the model. When a Slice Spiral feature is added to the CAM tree, the system adds the following items.
Boundary - This allows you to select an area of a part in which to confine the toolpath. Right-click this item to produce a shortcut menu with the following options.
Re/Select - Select this option to enable selection mode and assign the appropriate 2D geometry as a boundary to this feature.
Remove - Select this option to remove any boundary associated with this feature.
Slice Spiral -Right-click this item to produce a shortcut menu with the following options.
Edit - This opens the feature wizard so you can modify the settings used to create the toolpath. View the Slice Spiral Wizard to learn about the options available for this feature.
Semi/Finish - Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
View the following illustration for an example of the toolpath produced.
