A semi-finishing or finishing operation generating planar cuts parallel to the machining plane using surfaces, solids, or STL data. These can be processed in a by level or by area processing pattern. Optimal finishes can be obtained on models with vertical or near vertical topology. When a Z-Level Finish feature is added to the CAM tree, the system adds the following items.
Z-Level Finish - Right-click this item to produce a shortcut menu with the following options.
Edit - This opens the feature wizard so you can modify the settings used to create the toolpath. View the Z-Level Finish Wizard to learn about the options available for this feature.
Semi/Finish -Right-click this item to produce a shortcut menu with two options for modifying the computed toolpath.
View the following illustration for an example of the toolpath produced.
This image was roughed prior to applying the Z-Level Finish toolpath.
