With the axis control you can manually move the linear and rotation axes of the machine.
Main Features
Identify the machine axis limits
Identify the current axis position
Right-click the axis slider to enter a defined position or to set all axes to zero
Main Benefit
Determine if the machine limits are set up correctly
Determine if the collision check is set up properly
