Our 4 & 5 Axis packages deliver cutting edge CNC programming power, capable of handling your most demanding jobs with ease. Our multiaxis systems can do everything from indexing and wrapping to working with rotary toolpaths and performing full 4 & 5 axis simultaneous cutting.
Designed as a complete multitask machining solution, our Mill Turn system is built for the most complex of jobs. With it, you can program your C, Y, & B axis cutting movements on anything from single-turret/single-spindle setups to multi-turret/multi-spindle configurations.
BobCAM for SOLIDWORKS™
Loaded with cutting edge CAM power, our BobCAM for RHINO milling packages offers best-in-class 2.5 and 3 axis toolpaths, perfect for 2D & 3D milling. Powered by a user-friendly wizard driven interface, BobCAM makes it easy to apply efficient toolpaths and get parts out the door quickly.
Our 4 & 5 Axis BobCAM for RHINO packages deliver cutting edge CNC programming power, capable of handling your most demanding jobs with ease. With our multiaxis systems, you can do everything from indexing and wrapping to working with rotary toolpaths and performing full 4 & 5 axis simultaneous cutting.
Designed as a complete multitask machining solution, our Mill Turn system is built for the most complex of jobs. With it, you can program your C, Y, & B axis cutting movements on anything from single-turret/single-spindle setups to multi-turret/multi-spindle configurations, right inside of Rhino CAD.
Designing and programming jobs for your CNC turning centers has never been easier. The new BobCAM for RHINO Lathe system gives you the power to quickly create efficient toolpaths for all of your roughing, finishing, threading, and grooving operations, right inside of Rhino CAD.
Designed for precision manufacturing and cutting hard alloys, the new BobCAM for RHINO Wire EDM software lets you program 2 & 4 axis wirepaths within tight tolerance levels for all open and closed, inside and outside shape cutting.
Our BobCAM for RHINO Router CAM plug-in delivers efficient toolpaths so you can get your jobs done faster. The seamless workflow of the user-friendly interface offers an efficient way to go from designs to part programming right inside of Rhino CAD. It’s perfect for woodworking, engraving, and much more.
The BobCAM for RHINO plug-in for CNC laser, plasma, and waterjet machines delivers advanced 2-5 axis toolpaths and machining strategies, allowing you to handle your most demanding jobs with ease. With fully customizable cutting conditions, this system gives you complete control over how you cut your parts.
Turn your artistic imagination into a manufacturing reality with the new BobART, a first-of-its-kind artistic plug-in for Rhino CAD. This creative package allows you to do everything from importing vectorized PDFs and raster to vector conversions to embossing, engraving, and more. It’s perfect for sign makers, custom woodworkers, and more.
