Our 4 & 5 Axis packages deliver cutting edge CNC programming power, capable of handling your most demanding jobs with ease. Our multiaxis systems can do everything from indexing and wrapping to working with rotary toolpaths and performing full 4 & 5 axis simultaneous cutting.
Designed as a complete multitask machining solution, our Mill Turn system is built for the most complex of jobs. With it, you can program your C, Y, & B axis cutting movements on anything from single-turret/single-spindle setups to multi-turret/multi-spindle configurations.
Achieve a higher per job profitability when you optimize your sheet nesting capabilities with the new Nesting add-on. This powerful true shape nesting solution uses advanced algorithms and new sheet optimizers for smarter object patterning on standard and custom sheet shapes.
BobCAM for SOLIDWORKS™
