Tech Tuesday: 2 Axis and 4 Axis Wire EDM Examples
Posted April 12, 2022 4:44 pm   Published by    BobCAD-CAM ">
BobCAD V34 and BobCAM for Rhino V2 offer 2 Axis and 4 Axis Wire EDM machining. These two types of Wire EDM cuts include inside, outside, and open cuts. If the taper angle is continuous, you would need to simply select a 2 Axis Wire EDM operation. We begin by creating a two-dimensional drawing of the outermost boundary of the path of the wire. Then, go to the CAM tab and select Wire EDM for your machining job. Select your machine, and then go into the Stock Wizard to define the stock you have set up at your machine.
Stock Definition
In this 2 axis wire example, we will create an outside wire cut to cut out this shape. After defining the stock, the next page is the Machine Setup location for our work offset. After setting the work offset, we right-click on the Machine Setup option in the CAM Tree. Then we select 2 Axis Outside for this operation.
CAM Tree
If the taper angle is continuous, you would need to simply select the Taper option on the next page after selecting the geometry of the wire cut. The next pages are for setting your lead-in and lead-out for each wire cut, as well as the cutting conditions such as the feedrate and the offset to compensate for the diameter of the wire.
Note: After you compute this Wire 2 Axis feature, you can go to the Wire EDM tab at the top of the software program. If you click on Cutting Conditions, this opens a page where you can set parameters for each wire cut. You can save default settings for each wire cut depending on the stock thickness and material type for each future Wire EDM job.
In this example, we can see the 2 Axis Wire EDM path with a flat 2 axis cut and one with a taper angle.
Wire EDM 2 Axis 4 Axis
If the taper angle is not continuous along the path you are expecting to follow, you will select a 4 Axis Wire EDM operation. You would then select the type of cut accordingly, whether it is an open, inside or outside path. Then, select the top chain and then the bottom chain for the wire to follow along and sync up to both paths. In this example, you can see the circle as the top geometry selected and the rectangle as the bottom geometry selected.
Machine Setup
Right-clicking on the Upper Geometry and Lower Geometry options in the CAM Tree gives you the option to Modify Start Point. If the toolpath is crossing over each other in the 4 axis wire cut, you will most likely need to change the start point of these geometry selections. You need to make sure the start points line up correctly to create the desired 4 axis wire cut.
Wire EDM 4 Axis Wire Cut
forum.bobcad.com
