The new Turn Milling operation combines turning with milling tools to power through materials in record time! It is offered in BobCAD V34, BobCAM for Solidworks V9, and our new BobCAM for Rhino V2. In many cases turning operations are applied to the stock to remove material as quickly as possible. The only issue with turning material down quickly is when the chips don’t break properly and form large piles against the part called bird nests. These can be dangerous to the part finish, tool, and the machinist. The Turn Milling toolpath can be a super-efficient way to remove a lot of material on your 4 or 5 axis milling machines or your Mill Turn machines! By combining the efficiency of turning with the chip slinging power of an endmill, you can have the best of both worlds and power through material quicker than ever without having to worry.
In the example file shown, we begin by selecting the Mill Multiaxis operations in the CAM Tree of this part file. Then we select Turn Mill from our available Multiaxis operations. The next selection is the geometry selection for this milling operation. We have two different ways to select the geometry for this operation. Turn profile allows you to select wireframe geometry for
the operation. This is spun into a 3D model to utilize as the geometry of the operation. Part surface allows you to select a model for the geometry. If the model is not symmetric it is spun into a symmetric model to use as the geometry of the operation.
Next, we have the cutting direction for this operation. The two options are Bi-directional or Uni-directional. The uni-directional movement forces the cuts to move in a single directional for each slice. You can choose between either Positive or Negative direction. Bi-directional movement causes the direction of machining to alternate for each slice, from positive to negative directions.
Some other useful options in the Turn Mill operation include the depth step and stepover settings. The depth step distance determines the vertical distance between the cutting layers. The stepover distance determines the width of each pass that is being machined. Then, there is the axis offset setting. The user can set how far the center-line of the tool will be offset from the rotary axis. You can set a specific distance, or set it by the percentage of the tool diameter. This is beneficial for longevity of the tool for an endmill is not designed to be plunging into material constantly. Instead, the endmill will offset and machine mostly with the side of the tool.
forum.bobcad.com
