Tech Tuesday: CAM Libraries
Posted June 29, 2021 8:48 am   Published by    BobCAD-CAM ">
CAM Libraries
BobCAD-CAM has CAM libraries for every facet of your milling and turning parameters. Our CAM libraries aid the everyday machinist by storing and providing quick access to programming critical data. Create new, edit and call from the Tool, Holder, Adapter, Thread or Material libraries.
CAM libraries found on BobCAD-CAM's CAM software aid the everyday machinist by storing and providing quick access to programming critical data
The Tool Library
The Tool Holder Library
The Milling Tool Holder Library is used to create and modify tool holders and arbors. Each category on the left specifies a tool holder type, and each arbor that belongs in that category is shown on the right. The holders/arbors can be associated with a tool for simulation purposes.
The Adapter Library
The Adapter Library is used to define all adapters that are available in the system for mounting lathe or mill tools (live tooling) to the turret of a mill turn machine (or lathe with live tooling).
The definition of an adapter in BobCAD-CAM is a device that is used to mount either lathe or mill tools to the lathe turret of a mill-turn machine. The adapter is attached to a turret station and one or more tools are attached to the adapter. An adapter may also be called the tool holder or tool mounting block (also known as VDI or BMT tooling). Adapters can hold one or more tools in one or more orientations on the physical machine. Each adapter either holds static lathe tools or it is used to drive live (mill) tools.
Thread Library
Stock Material Library
The Stock Material Library contains all of the information for the available stock materials. You can create and modify the Material Groups which contain multiple Material Types. Material Types can also be created, modified, and added to the Material List. The Material List groups the materials by grade and lists them in alphabetical order.
The feeds and speeds for each Material Type are fully adjustable, and these parameters are set in the Stock Material Feeds and Speeds dialog box which is displayed when you click Add Material or Modify Material in the Stock Material Library dialog box.
All jobs contain a Stock Material item in the tree that defines the stock material from which the part is cut. The selected material type is used for automatic feeds and speeds calculations in the CAM Wizards.
Try CAM Libraries options in BobCAD-CAM V33 today!
