Tech Tuesday: Chuck Wizard
Posted July 27, 2021 3:21 pm   Published by    BobCAD-CAM ">
The Chuck Wizard is used to define a chuck for multi-axis mill turn machines. BobCAD users have the ability to define the specific chuck they are using on their machines to simulate in the BobCAD software program. The Chuck Wizard dialog box is accessed from the Machine Definition of the Current Settings. Here is the workflow to access the Chuck Configuration dialog from the Machine Definition:
  • Right-click on CAM Defaults from the CAM Tree
  • Select Current Settings
  • Select the Mill Turn machine you are using
  • Click on Machine Definition
  • Click on C axis rotation, where you now can see the button to click on the Chuck Wizard
There are many parameters that you can manipulate in the Chuck Wizard to simulate the chuck you are using, including:
Rotation Axis
The rotation axis of the chuck is set in reference to the machine zero coordinate system. (This defines the rotation axis of the chuck)
Base Point
This parameter determines the distance from the machine zero location or the front face of the chuck, to the chuck rotation axis. (The face of the chuck is aligned to machine zero location when creating the geometry files).
Index Direction
This parameter defines the direction for positive rotation of the chuck, either the clockwise or counterclockwise direction.
Chuck Body
You can either simply type in the certain parameters of the chuck body:
  • Body Diameter – sets the overall diameter of the chuck.
  • Inner Diameter – sets the inner diameter of the chuck.
  • Body Thickness – sets the thickness of the chuck.
Or you can select an STL file for the model of the chuck. You will need to select whether the STL file was modeled in inches or in mm.
Flip Orientation
The direction of the extruded chuck is determined by the rotation axis. The default direction of the extrusion is along the positive of the rotation axis vector. This can be changed by selecting the following check box.
With the checkbox cleared, the chuck body is extruded along the positive direction of the rotation axis.With the checkbox selected, the orientation reverses and is extruded along the negative direction of the rotation axis vector.
Flip Rotation
Next, you will be defining the parameters of the jaws of the chuck.
There are parameters to set the number of jaws. This determines how many jaws are on the chuck. The jaws are all equally spaced around the chuck. Other parameters for the jaws of the chuck include:
Limits
  • Min – defines the minimum amount of travel toward the center of the chuck.
  • Max – defines the maximum amount of travel toward the outside of the chuck.
  • Initial – defines the initial position of the jaws.
First Jaw Angle
Defines the initial vector direction of the first jaw. Subsequent jaw vector directions are calculated from this position.
Geometry
The dimensions of the chuck body can be defined with manually entered values for each of the parameters:
Geometry
  • Jaw Height (1) – sets the height of the jaw.
  • Step Height (2) – sets the height of steps in the jaw.
  • Step Depth (3) – sets the depth of steps in the jaw.
  • Thickness – sets the thickness of the jaw
Or you can select an STL file for the model of each of the jaws of the chuck. You will need to select whether the STL file was modeled in inches or in mm. This way, you can model the chuck and the jaws in the BobCAD simulation to the exact specifications as you have on your machine.
Try the Chuck Wizard for your simulation in BobCAD today!
