Tech Tuesday: Work Offset Numbers
Posted November 9, 2021 3:29 pm   Published by    BobCAD-CAM ">
In the new versions of BobCAD-CAM, you can now add and edit multiple work offsets with ease. You can open the new Work Offset Pattern page at any time to post the operations of an existing machine setup into multiple work offsets.
Work Offset Numbers
This dialog will allow you to set and adjust the posting order used in the output, as well as control the pattern and spacing used to illustrate the pattern in the graphics area and simulation. The main Work Offset number is initially set up in the Machine Setup dialog when the job is created and can be edited at any time.
Here in the Work Offset Pattern dialog, there are different pattern types to designate exactly where each work offset is on the table of your machine. These different pattern type options include:
  • Array – creates the pattern with a defined distance interval and number of copies along the X- and/or Y-axis direction.
  • Translate – creates a pattern with a defined number of copies using either the Delta or Sketch/Enter method.
  • Rotate – creates a pattern with a defined angle interval and number of copies rotated around a user-defined point or line (3D).
  • Point – creates a custom pattern, by allowing you to select a start point and various endpoints to place the copies in X, Y, and Z space.
  • From UCSs – creates a pattern based on the UCS you choose. The position of the Machine Setup, in relation to the WCS will dictate the position of the copies on the selected UCSs.
You can also sort the sequence of the machining operations in a specific order. Different categories to set the machining order include:
  • By Tool Per Work Offset – will prioritize completing all operations utilizing the same tool within the same work offset before moving to the next work offset.
  • By Tool – will prioritize completing all operations with the same tool, one operation at a time on all work offsets, before moving to the next tool.
  • By Work Offset – will complete all operations on one work offset before moving to the next work offset.
These are just a few of the options here in the Work Offset Pattern dialog. You can try out this new functionality in BobCAD V34, BobCAM for Solidworks V9, or our new plug-in BobCAM for Rhino V1.
Work offset patterns for Tombstones and other rotation fixtures? Use this link to follow along with a step by step example ( https://bobcad.com/components/webhelp/BobCADCAMV34/Content/TutorialsMain/CAM/Mill/Machine_Setup/Work_Offsets_for_Tombstones.htm) found in our V34 help system.
www.bobcadsupport.com
forum.bobcad.com
