BobCAD-CAM Version Matrix
SUPPORTED LANGUAGESV30V31V32V33
ENGLISH
SPANISH
TURKISH
JAPANESE
PORTUGUESE
CZECH
GERMAN
GENERAL/SYSTEMV30V31V32V33
View to Active UCS
View Rotation Keys
Document Templates
Customizable Ribbon Bar
System Setting Dialog Enhancements
Rhino 6 File Import
Redesigned User Interface
Contextual CAM Ribbon
Document Toolbar
Backstage
New Docking Planes
User Profile
Quick Access Toolbars
New Print Dialog
Settings Part / Defaults Updates
File Preview
Network Licensing
Online License Registration / De Registration
64-Bit Application
CAM - 3D Milling OptionsV30V31V32V33
New Steep Shallow Toolpath for Mill
Remove Corner Pegs Enhancements
Flat Lands Reverse Cutting Order
Use Lead In/Out for Advanced Roughing
Wall Clearance For Advanced Roughing
Remove Air Cuts for Advanced Z Level Finish
Skip First Cut for Z Level Finish
UP/ Down Feedrate Control for Equidistant Offset
Trim Adaptive Passes for Advanced Planar
Barrel Mill Supported for 3 Axis Pro Toolpaths
Advanced Allowance
Detect Stock Thicker Than
Trim Adaptive Depth Step Passes
New Automatic Arc Lead
New Lead In – Reverse Orthogonal Line
Multiple Surface Selection for Flow Line
Expand Rest Machining Area
Improved Round Corners / Smooth Corners
Shift Link Location for Advanced Z Level Finish
Start Point Control for Advanced Z Level Finish
Adaptive Breakthrough Amount
New ADV Rough Patterns: Parallel, Offset, Morph Spiral
New 3 Axis Premium Module
Undercuts for Advanced Z Level Finish
ARC Leads for Adaptive Roughing
Dynamic Holder Collision Avoidance
CADV30V31V32V33
Align to Coordinate System
Add / Edit Hole Property
Advanced Holes
CAD Tree Optimization
Delete CAD Tree History
Document Templates
File Preview
Construction Geometry
Layer Attributes
New UCS Manager and Editing Options
New Wire Frame Creation Options
New Rectangular and Circular Plane Options
Surface Edge Extension Enhancements
Auto Dimension
Leader Arrow Notes
Mirror About Planar Face
Geometry Selection Manager
Scale Sketch Handle
3D Imprint
Fillet / Chamfer Chains
Share Corner Offset
Measure 1 & 2 Enhancements
Text Alignment
CAD Cleanup Reporting
CAMV32
Stock Wizard
Rectangular Stock
Cylindrical Stock
Wire Frame Stock
Solid Model Stock
Stl Stock
Job Based CAM Tree
Revolved Stock
Multiple Machine Setups
Toolpath Pattern Array
Toolpath Pattern Translate
Toolpath Pattern Point
Index System
Wrapping Groups
Multi-Threaded 3 Axis Pro Toolpath Calculations
Expand and Collapse CAM Tree Items
Dynamic Machine Strategies in the CAM Wizard
Dynamic Posting Order
Geometry Preview
Operation Preview
Default Parameter Templates
Job Templates
User Defined Machining Strategy Templates
New Machining Order Dialog
Default Machining Order Options
CAM Tree Flyouts
Redesigned Tool Library
Work Offset Pattern
Fixtures
Mill Turn Chuck Jaws
Subprograms for Operations
Keep Bounding Geometry (Stock Wizard)
Simulation Work Offset Pick Point Method
SelectionV32
Open & Close Chain Selection
Color, Layer, Line Style
Pick and Match
Face and Edge Picking
Constant Z Selection
Loop Selection
Toolpath FeaturesV32
Save/Load Feature
Copy/Paste Feature
Keep Feature Depth
Groups
Locked Features
Update All Geometry
Toolpath Editor
Edit Operation
Apply To All Features/Operations
Groups for Index Systems & Wrapping Groups
Save Feature Defaults
User Defined Strategy Templates
Speed and FeedsV32
Material/Cutting Conditions
Surface Radius Based Feed Optimization
Tool Contact Based Feed Optimization
Convert Rapids To Feed
Independent Lead In/Out Feed
Adaptive Feed Rate Volume Based
Adaptive Feed Rate Chip Thinning Based
ToolsV32
Tool Library
Tool Types: Tapered Endmill, T-Cutter, Dove Mill, Lollipop
Tool Holder Library
Tool Crib
User Defined Tool Profiles(Form Tools)
Single Window Tool Library
Tool Library Search/Filter
SimulationV32
Machine Simulation
Setup Sheets
Backplot
Backplot with Detailed Information
Toolpath Statistics
Multi Window View
Measure Grid
Section View/Layering
Click to Advance Toolpath
Zoom Window
Show Previous View
Next Feed Move
Move List Bookmarks
Keyboard Shortcuts for ISO Views
Machine Coordinate System Display
Material Display Mode Retention
CADV32
Preview
User Coordinates System(s)
Dimensions
Measure
Text
Text Along a Curve
Show/Hide Axis
Customizable Interface
Standard View
Section View
Dynamic CAD
Snap Grid
Show/Hide Gnomon
New Geometry Picking Interface
Instant Preview
Construction Lines
Dynamic UCS
Layer Attributes
Auto Dimensions
Leader Arrow Note
Wire FrameV32
Point Sketch
Point Coordinates
Point Incremental
Point End
Point Intersection
Point Intersection on Extension
Point Arc Center
Point Perpendicular
Point On Entity
Line Sketch
Line Coordinates
Line Join
Line Tangent
Line Parallel
Line Angle
Line Angle Tangent
Line Chamfer
Line Chamfer Single Click
Line Continuous
Arc Sketch
Arc Coordinates
Arc Snap
Arc Fillet
Arc Fillet Chain
Arc Fillet Single Click
Arc 3 Entities
Arc Center 2 End Points
Arc Between 2 Points Diameter
Arc Between 2 Points Radius
Fit Arcs
Rectangle
Rectangle 2 Points(Sketch)
Rectangle 2 Points Center Top
Rectangle 3 Points Length Width
Rectangle 3 Points Half Length Width
Rectangle Angle
Ellipse
Ellipse with Spline
Spiral
Contour
Offset
Offset Sharp Corner
Continous Sketch
Equalize
Project Curves
Hole Pattern
Point Pattern
Gear
Sprocket
Roller CAM
Shape Library
Shape with Origin Commands
Spline Interpolated
Spline Fit
Spline Blended
Spline Approximated
Spline Multi Geomtery Pick Method
Editing ToolsV32
Mirror
Rotate
Rotate 3D
Translate
Trim Extend
Break
Extract Edges
Extract Edges Project to Z
Stiching
Reorganize
Explode
Reverse Surface Normal
Drag Corner
Deform
Stretch
Nonuniform Scale
2D Boolean
Spun Profile
Dynamic Scale/Scale Sketch Handle
Unwrap
Unwrap with Chain Selection
SurfacesV32
Rectangle Plane
Rectangle Angle
Circular Plane
Circular Plane 2 Points Radius
Circular Plane 2 Points Diameter
Circular Plane Center 2 End Points
Circular Plane 3 Points
Planar
Extrude Curve
Extrude Surface
Revolve
Sweep
Cross Section
Skin
Offset
3 Edge
4 Edge
Multi-sided Patch
Fillet
Extend
Extend with Face Selection
Intersection Curves
UnTrim Surface
Break Surface
Swung
Ruled
SolidsV32
Sphere
Cube
Cube with Origin Control
Cylinder
Torus
Fillet/Chamfer
Boolean Add/Subtract/Intersect
Extrude Boss
Extrude Cut
Split
Shell
Imprint
Lathe/Mill Turn OptionsV30V31V32V33
Lathe: New Pecking Options for Hole Cycles
Lathe: Chip Breaking Cycles
Mill Turn: Chuck Wizard
Stock Tracking
Trim to Stock
Mill TurnV32
Support for Many of the Most Popular Mill Turn / Live Tooling Machines
Multiple Turret Machine Support
Support for Subspindles
Tool Crib for Easy Mounting of Tools and Adapters
5 Axis Milling Spindle Support
Job Setup Wizard
MDI ( Manual Data Input ) for Motion, Part Transfers, Tailstocks and More
Turret and Tool Adapter Library
New Lathe System
Wire EDMV28V29V30V31
Wire EDM Jobs
CAM Wizard
Stock Wizard
Wire EDM Features
2 Axis Inside, 2 Axis Outside and 2 Axis Open (No Taper)
2 Axis Inside, 2 Axis Outside and 2 Axis Open (Constant Taper)
Land and Taper (Land on Top or Bottom)
Cut One or More Profiles in a Single 2 Axis Feature
4 Axis Inside, 4 Axis Outside and 4 Axis Open
4 Axis Syncing
Dynamic Machining Strategies
Wire EDM Simulation
BobARTV30V31V32V33
Flat End V Tools
NestingV28V29V30V31
Screen Selection
Batch Selection
Holes
Dados
Multi Part Nesting
Part Priority
Part Quantity
Sheet Size
Multiple Sheets Supported
Nest Only
Nest & Toolpath
Cut Direction Control
Machine Order Control
Part Rotation
Distance Between Parts
Stock Margin
Fill Order
Tabs
Part in Part
True Shape Nesting
Export Sheet to DXF
Nesting Job
Nesting Wizard
Layer Sorting Control
Filler Quantity
Angle List
Grain Direction
Advanced Part Parameters
Custom Sheet Shape
Variable Stock Margin
Advaned Sheet Settings
Max Part Distance
Thermal Distance
Cut Large Parts Later
Filler Part Settings
Best Nesting Direction
Nest only full Quantity
Flat End Fit
Nesting Optimizers
Remnant Sheet Settings
PRODUCT FAMILYV33
CAD
Mill Express
Mill Standard
Mill Professional
Mill Premium
Mill 4 Axis Standard
Mill 4 Axis Professional
Mill 5 Axis Standard
Mill 5 Axis Professional
Wire
Lathe
Mill Turn
BobART
Editor Standard
Editor Professional
NCEditor Standard
NCEditor Professional
Probing
GENERAL CAMV30V31V32V33
Probing
Hole Recognition
Knowledge Base
Fixture Selection
Work Offset Patterns
CAM Tree Flyouts
Job Templates
Posting: Transform Plane Output ( G68.2)
Posting: Origin Tracking
Backplot Start & End Indicators
Edit Operations from CAM Tree
Conventional Feed Control
Adaptive Feedrate Control (Radial Chip Thinning)
Adaptive Feedrate Control (Volume Based)
Feedrate Control (Dog Leg Handling)
Lead-in and Lead-Out Feed Control
Advanced Feedrates
Post Processor Encryption
Bounding Cylinder for Cylindrical Stock
Backlot
Lock and Unlock Operations
Update All Geometry
GENERAL CAM: ToolsV30V31V32V33
Barrel Mills: Standard, Tangent, Lens and more
Machiningcloud Direct Import
XML Import/Export of Tool Library
Flat Bottom V Tools
Tool Library Search Filter
Tool Holder Library
Tool Crib
Tool Library
User Defined Tool Profiles (Form Tools)
Tool Types: Tapered End mill, T-cutter, Dove Mill, Lollipop
GENERAL CAM: SimulationV30V31V32V33
Temporary Relative Job Values
Smooth Cutting Quality for X Y Cuts
Retention of Material Display Mode
Move List Bookmarks
Next Feed Move
Show Previous View
Zoom Window
Click to Advance
Section View/ Layering
Measure Grid
Multi-Window View
Ruler Display
Automatic Chip Removal
Machine Simulation
CAM: Hole Making OptionsV30V31V32V33
Customizable Hole Making Knowledge Base
Hole Feature Recognition
Pecking Cycles for all Drill Operations
5 Axis Drilling
Cross Drilling
Multi Size Hole Drilling
Multi Depth Drilling
Hole to Hole Sequence Control
CAM: 2D Milling OptionsV30V31V32V33
Multiple Pocket Drill Tip Positions
New Side Roughing Options
Corner Slowdown
New Machine Sequence Options
Automatic Facing Boundary Selection
ADV Pocket Patterns: Parallel, Offset, Morph Spiral
Drag Knife
Toolpath Editor
Adaptive Facing Pattern
Trim and Extend (2D Profiles)
Toolpath Statistics Dialog
Toolpath Patterns by Point Location
Peck Plunge
Multiple Step Chamfer
Minimize Tool Retracts
CAM: 4 Axis OptionsV30V31V32V33
Barrel Mill Supported for Advanced Rotary
Detect Stock Thicker Than for Advanced Rotary
Intermediate Steps for Advanced Rotary
New Advanced Rotary Rough and Finish
Multiaxis Feed Types
Gouge Check with Check Surfaces for Rotary
Trim to Stock for Rotary
Machine Sequence Control for Cross Drilling
Adaptive Stepover for Rotary
Wrapped and unwrapped Geometry Supported
Multiple Index Locations
CAM: 4-5 Axis OptionsV30V31V32V33
Barrell Mill Tool Supported
Automatic Arc – Tool Axis Orientation
Limits Relative to Surface Normal
Multiaxis Roughing – Undercut Machining
Toolpath Smoothing
Feedrate for Direct/Spline Links
Side Tilt By Contact Point
Minimize Tilting
Swarf Toolpath Enhancements
Multiaxis Roughing: Rotational / Periodic Pocket
Gradual Front Shift Change
Gradual Side Tilt Angle Change
Clearance Linking: Blended Spline
Automatic ARC Lead
Automatic Start Height Lead
Swarf Sorting: Start from Bottom
Automatic Clearance Area
4 Axis Tool Axis Smoothing
Multiaxis Roughing – Dynamic Holder Collision Checking
Extend Cuts for Stock
Swarf: Normal to Guide Curve
