BobCAD-CAM comes with the ability to generate toolpath and code for laser, plasma, and waterjet machines.
To access these machine types, you create a machine as explained in the Machine Configuration help topic. You can also select a BC machine (that is installed with the software) and if necessary, modify the definition to match your machine.
After creating a machine, you can access these machines in one of the following two ways.
1 In
the
CAM
Tree, right-click
CAM Defaults, and click Current Settings.
2 In the Machine Parameters page, select the machine Make and click Set As Default.
This is now the default machine for all new files that are created after making these changes.
1 Right-click
CAM Defaults,
and click New Job. You
can also click New CAM Job
in the Modules
menu.
2 In the Machining Job dialog box, under Machine, select the machine to use for the job.
3 Click OK to select the machine and create the job.
1 In
the
CAM
Tree, right-click
Machine, and click Edit.
2 In the Machine Selection dialog box, select the Make, and click OK.
1 In
the
CAM
Tree, right-click
Milling Jobor Nesting Job, and
2 In
the Machine Parameters page, next
to Make, click
3 In the Machine Selection dialog box, select the machine Make and click OK.
4 You can also make any needed changes in the Milling Settings dialog box before clicking OK and they are saved with the selected machine for the current part only.
To learn about all of the parameters for Current Settings, view the Current Settings dialog box.
The parameters that are used to create operations for these machine types are the same as explained in the appropriate CAM Wizard topics. For example, the profile operation parameters are explained in the 2 Axis Wizard. The only difference in the Milling Wizards for these machine types is the Tool page as explained next.
Tool Crib - opens the Tool Crib.
Assign Tool Holder- opens the Tool holder Library.
Tool Data
Diameter - sets the kerf width of the cut. Some machines allow this to be an adjustable value depending on the actual tip of the tool or nozzle (in the case of waterjet machines). Set this to the actual kerf width.
Gas Type
AIR - selects air as the assist gas.
OXYGEN - selects oxygen as the assist gas.
OXYACETYLENE - selects oxyacetylene as the assist gas.
Tool Label - since the tool cannot be changed, this box is only an informational display.
Holder Label - displays the name of the tool holder that is assigned.
Cutter
ON - activates the cutter in the posted program.
OFF - deactivates the cutter in the posted program.
Gas
ON - enables the assist gas while cutting.
OFF - disables the assist gas while cutting.
Shutter
Open - opens the shutter while cutting.
Close - closes the shutter while cutting.
Feeds and Speeds
Use System Feeds and Speeds - not available. Feeds and speeds must be manually entered as follows.
Feedrate - sets the post processed feed to use while cutting.
Pierce Dwell - sets the time (usually in seconds, some machines may differ) that the operation dwells to ensure a clean pierce at the beginning of a cut.
Pulse Frequency - sets the pulse frequency passed to the machine.
Power Setting - selects the power setting passed to the machine.
Torch Height Control - some machines allow the torch height control to be set through the NC program. If it needs to be set for your machine, enter the value here.
Arc Slowdown % - specify a feedrate slowdown for arcs. This is the percentage of the feedrate by which the machine slows down when cutting an arc.
Feeds and Speeds
Pressure Type - select the water pressure setting passed to the machine: High, Med, or Low. The actual PSI pressure cannot generally be set through an NC program.
