In this Topic Show
The Patterns page gives you control over the pattern of the cut, and the compensation that will be used to complete the operation.
Continuous - sets the finishing
pass to a single pass along the geometry.
Alternate - breaks the finishing
pass into separate groups defined by either vertical faces, turned diameters,
or a combination of the two.
Both - will Face Vertical, and
Turn Diameter with opposing direction of cuts.
Face Vertical Only - will only
cut vertical walls.
Turn Diameter Only - will only
cut geometry running parallel to the center of rotation.
Include angled walls - will allow
for geometries that are not perfectly vertical or horizontal to be cut
as well.
Continuous |
Alternate |
Turn Diameter Only |
Face Vertical Only |
Both |
Excluding Angled Walls |
Each tool has a theoretical point placed on it as seen in red in the animation below. In the case of tools with a radius of any size, this point is not actually on the tool, but on the horizontal and vertical intersections of the radius. It is this point that the toolpath plots out. When compensation is used, it is designed to place the actual tool and not just its theoretical point on the geometry. This can be accomplished with System Compensation, Machine Compensation, or a combination of the two.
System Compensation
This
specifies whether or not the system compensates for the insert geometry
and the tool nose radius.
Off - the selected geometry is used as the program path; Machine Compensation should be used.
On with Collision Detection - the system compensates for the tool nose radius and the insert geometry and avoids any detected collisions.
On without Collision Detection - the system compensates for the tool nose radius and the insert geometry without checking for collisions.
Theoretical Point |
System Compensation: Off |
System Compensation: On with Collision Detection |
System Compensation: On without Collision Detection |
Outputs the necessary codes to allow
for the user to enter compensation data at the machine. When this
is done, the machine will alter the path based on the data entered
at the machine. This can even be used in combination with System Compensation
in order to compensate for tool wear or other unforeseen variables.
Off - no compensation commands are output in the posted program.
Comp Left / G41 - outputs the left compensation command in the posted program.
Comp Right
/ G42 - outputs the right compensation
Once the Pattern variables have been set, click
to continue to the Parameters page.
