Lathe Groove Tool Page
The Groove Rough and Finish operations have only one tool type to choose from. It is good practice to have all the tools for the job loaded into the Tool Crib at the start of the job. By this point, those tools should already be in the Tool Crib, and the system will have pulled appropriate tools for each operation from the Tool Crib. From this tool page, you can either, choose a different tool from the Tool Crib, go into the Tool Crib to add tools from your Tool Library, or enter tool specific data manually into the Tool Data Section of the page.
CheckBoxCleared.png Show Tool Holder - Selecting this check box will alter the graphic to show the holder as well as the insert.
Deselected
Selected
Tool Data
Tool Orientation
NOTE: The Orientation Number defines whether the cut is inside or outside of the geometry and the direction of cut and will be set for you based on the Feature Type and Region chosen in the Feature page.
Machining Data
CheckBoxCleared.png Clear the Override Offsets check box to use the tool number to set the Offset Register value.
CheckBoxSelected.png Select the Override Offsets check box to allow for manual editing of the Offset Register value.
Spindle Direction
Feeds and Speeds
Groove Rough: Once the Rough Tool variables have been set, click Wizard_NextButton.png to continue to the Patterns page.
Groove Finish: Once the Rough Tool variables have been set, click Wizard_NextButton.png to continue to the Patterns page.
