In this Topic Show
The Pattern Repeat operation is designed to remove the bulk of the stock from the workpiece and is ideal for cast stock or stock that is close to the shape of the final part. Exactly how this operations are accomplished is defined in the subsequent pages of the Basic Finish operation. Each of the pages allows you to define the variables in order to tailor the machining process to fit your needs. Use the following links to jump to the specific topics for each available Pattern Repeat operation page:
To continue to the Pattern Repeat Tool topic, click here.
