Introduction to the Backstage
This topic will explain the Backstage, and the file options found in it. This topic will also provide links for those portions that are expanded into their own topic.
Backstage
The Backstage is where all the file options, Themes, Help options, Settings Part and Default, User Profiles, and keyboard shortcuts can be found. All of these options found in the Backstage are explained below.
- New - The New command opens a new file. This does not close any files that are currently open.
- Open - The Open command is used to open a previously saved file. The Open dialog box displays for you to locate and select the file to open. To view the supported file types or to find a file that isn't showing, click the arrow next to Files of Type. The list of supported file types is shown, and you can select the type of files that you want to display in the dialog box, such as All Supported Files.
- Save - The Save command is used to save any changes that were made to the current file. If the file has not already been saved, the Save As dialog displays for you to name the file and select the location to which the file is saved, Once the file has been saved, the Save command saves the file without opening a dialog box.
- Save As - The Save As command opens the Save As dialog box for you to name the file, select the file type, and select the location to which the file is saved. The file type is set to BobCAD files (.bbcd) by default. To view what other types of files can be saved, click the Save as type arrow to view the list. You can then select the type of file format in which the file is saved.
Saving as file types other than .bbcd
- Merge - The Merge command is used to open a file and add its geometry contents into the currently open document.
- Close - The Close command closes the currently open document without exiting the software. If changes have been made since the file was opened, a dialog box is displayed with a question about whether to save changes to the file:
Yes - If the file has been saved previously, the file will be saved and closed. If the file has not been saved previously, the Save As dialog will appear prompting you to name the file and choose a save location. Once saved the file will automatically be closed.
No - The file will be closed.
Cancel - The file will remain open.
- Print - The Print command is used to print what is visible in the current graphics area. The Print dialog box opens for you to alter the print settings and select the printer.
- Recent Files - will list all recently opened saved files in the backstage area. Double-click a file name in the list, and it will be opened as a new graphics area tab.
- User Profile - control the appearance of the user interface. You can use these options to select between predefined combinations of graphical details, colors, and fonts. Click User Profile to jump to the topic that covers this in detail.
- Customize Shortcuts -Keyboard shortcuts allow you to tie a BobCAD-CAM function to a particular combination of keyboard keys, which will, once assigned, launch that particular function when they are pressed. Clicking Customize Shortcuts launches the Customize Shortcut Keys dialog to allow you to create, or alter the current shortcut key assignments. Click Customize Shortcuts to jump to the topic that covers this in detail.
- Help - gives you access to Support, Licensing, and Licensing Tools. Click Help to jump to the topic that covers this in detail.
- Settings Part - exits the Backstage, and opens the Settings Part dialog box. Click The Settings Part Dialog Box to jump to the topic that covers this in detail.
- Settings Default - exits the Backstage, and opens the Settings Default dialog box. Click The Settings Default Dialog Box to jump to the topic that covers this in detail.
- Exit - is used to close the software. If changes have been made to any currently open files, a dialog will be displayed for each file, one at a time, to allow you the opportunity to save those files that have not already been saved, or to Cancel the close request.
Cancel - The file, and software will remain open.
