Mill Turn Example 1
This tutorial walks you through creating a Mill Turn job to completely machine an example part on the BC 2T 2S mill-turn machine as shown in the Mill Turn Tutorials topic. This is a two turret, two spindle configuration with live-tooling and Y-axis machining capabilities on the upper turret. In addition to understanding the machine for which we are programming, it is also important to know the naming convention used for the submachines (work zones) as follows.
BC 2T 2S Mill Turn Machine
BC 2T 2S Submachine Naming
UT_MS = Upper Turret, Main Spindle |
UT_SS = Upper Turret, Sub Spindle |
LT_MS = Lower Turret, Main Spindle |
LT_SS = Lower Turret, Sub Spindle |
Example Part
The following images show our example part. For this tutorial, we machine the part using stock that is already cut to length. For this reason, we create our features as though the model is split into two halves: front and back. This allows us to machine the front half of the part on the main spindle before transferring the part to the sub spindle and machining the back half. This is important to understand as this determines how we create some of our features.
Machine Setups
For this tutorial, all features are created using one of two machine setups: one for the front side and one for the back side of the part. The following images show the location and orientation of the machining origin (work offset) for each setup.
Machine Setup 1 |
Machine Setup 2 |
The Mill Turn job, stock, and machine setups are already defined in the example file provided for this tutorial. If you would like to learn more, view the Mill Turn Job Setup Example.
Final Result - All Toolpath
Example File Download
The BobCAD part file for this tutorial is available for download at: http://bobcad.com/helpfiles. If you are connected to the Internet, you can click the link provided to download and save the Mill Turn Example 1 BBCD.zip file. After extracting the zip file, you can open the BobCAD file to follow along with this example. In the example file provided, the job, stock, and two machine setups are already defined.
- Loading the Tool Crib from a file
- Changing the default submachine for new features
- Creating Lathe features:
- Facing
- (OD) Turning
- Hole Drilling
- (OD) Grooving
- (ID) Turning or Boring
- Creating Mill features:
- Face milling
- Face drilling
- Cross drilling
- Using the various Posting modes for Mill Turn
- Geometry selection tips and using CAD layers
- Using Modify Start Point for profiling
- Modifying machining strategies
- Changing tool assignment in the Tool Crib
- Simulating the program
- Verifying the tool assignment/tool numbering
- Posting the NC program (G-code)
Part 1) Load the Tool Crib from a Saved File
For this example, we load the Tool Crib with all tools that we want to use for the job. This way, we only open the Tool Crib to confirm the proper tool selection or to change the default assignment, for example, when selecting a finish tool for a rough operation or vice versa.
Tip: The ability to save and load the Tool Crib is an invaluable tool that can save a significant amount of time when creating Mill Turn jobs in BobCAD-CAM. If you have resident tools and/or adapters, or tools and adapters that are generally always mounted to the turret of the physical machine, then you can load and mount these tools in the Tool Crib once, and then save the information to a file to use as a template. This way you can just load the file, and you only need to add additional tools as needed per job. You can even save a Tool Crib for each machine or each common configuration that you use.
- In the CAM Tree Manager, right-click Mill Turn Tools, and click Tool Crib.
The Mill Turn Tool Crib displays. - Click the Load
button.
The Open dialog box displays for you to select a previously saved tool crib file. - Navigate to the Mill
Turn Example 1 folder, and click to select the Mill
Turn Example 1.mttcribs file, and click
Open.
Notice that the upper turret and lower turret devices now contain all the adapters and tools needed to complete the entire job. The mounting parameters are already set as needed to match how we are mounting our tools on the physical machine. - Click OK to save the tool information to the job.
Part 2) Change the Default Submachine
The first three features that we create use the LT_MS (lower turret, main spindle) submachine or work zone. Instead of changing the submachine in the Posting page of each feature, we change the submachine in the CAM Tree to determine the default submachine for creating new features.
- Under Machine
Setup - 1, right-click the current submachine name (UT_MS),
and click Edit.
- Under Submachine
Name, click the down arrow, and select LT_MS.
- Click OK
to update the default submachine.
All machining features created under Machine Setup - 1 are automatically set to use this submachine. The submachine can always be changed in the Posting page of the wizard.
Part 3) Create a Turning Feature - Lathe End Face
Machine Setup 1
It is important to think about the machine setup (machining origin) when creating machining features for Mill Turn jobs. All of the features that we create to machine the front half of the part are created under Machine Setup 1. The machining origin for this machine setup is at the front face of the part, not the stock, (we are facing to zero).
Right-click Machine
Setup - 1, point to Turn Features,
and click Lathe End Face.
The Geometry Selection page appears.
Tip: The Lathe End Face feature is designed to face the part to zero. Because the front of our part is flush with the machine zero, and since the stock we are cutting extends beyond that, geometry selection is not necessary. Positioning your future parts with this in mind can save you a considerable amount of time!
- Click Next>> to go to the Feature settings.
Define the Feature, Machining Strategy, and Posting Settings
The Feature settings do not need to be adjusted in this case, so click Next>> to go to the Machining Strategy.
- The default template, Rough, doesn't need changed, and we do not need a finish operation. We simply use the roughing operation to cut
the face to its final depth.
Click Next>> to go to the Posting settings. -
Under Posting Parameters, click the down arrow and select Canned Cycles.
Note: Notice the Submachine group in the Posting page of the wizard. You can always change the submachine for the feature from this location, in the event it is different from the default submachine selected in the CAM Tree.
Define the Rough Operation Parameters
Note: In this example, we loaded the Tool Crib before creating our job. This was done to show how much faster this method is, but you do not have to work this way. You can always load and mount tools in the Tool Crib as you create machining features. BobCAD-CAM allows you to work to your preferences.
Next we open the Tool Crib simply to verify the correct tool assignment (this step is not actually required, but is done for example purposes). We can determine which tool is selected by viewing the Tool Label, but it can also be helpful to open the Tool Crib to view and confirm the mounting orientation of the tool for each operation.
Click the Tool Crib button.
Notice in the device tree on the left that the 80 Deg. 1/64 Rough Turning tool is selected under the lower turret Station #17 (the first station of the lower turret).
Note that only the lower turret displays in the device tree, because our feature is set to the LT_MS (lower turret, main spindle) submachine.
With the 80 Deg. 1/64 Rough Turning tool still selected, click OK.
Important: When opening the Tool Crib from within a CAM Wizard, the tool that is selected when you click OK is assigned to the operation. Always be sure that the correct tool is selected before clicking OK in the Tool Crib. (The tool can be selected in the Device Tree or the Tool list.)
Click Next>> twice to go to the Parameters.
Under Parameters, make the following changes:
Depth of Cut = 0.030
In the Finish Allowance group, set:
- Z Allowance = 0.00
X Allowance = 0.00
At the bottom of the wizard, click Compute to calculate the toolpath.
Simulate the Feature
Before creating another feature, we simulate to confirm the toolpath is correct. The following steps provide an example of some settings that you may want to use during simulation. You can use some or all of these settings when simulating other features later in this tutorial.
To open simulation, click
above the CAM Tree, or right-click Mill Turn Job and select Simulation. -
The following provides some suggested simulation settings to get started.
- In the Simulation group of the Simulation tab, ensure
Machine Focus is set. - On the Simulation tab,
under Visibility, click
down arrow under the
Machine
Housing button and ensure it is set to Show. - Under Visibility, click
the
Toolpath
button to hide the toolpath from view. - Confirm that the
Workpiece and
Stock
buttons are set to show the workpiece and stock. - Use the
Simulation
RunSpeed slider
to adjust the playback speed of simulation as needed while simulating.
Click the
Run
button to play the simulation.
To close the simulation, click the
Exit Simulation button.
For more help with our extremely powerful simulation, view Getting Started with Simulation.
Hide Geometry and Toolpath
Now that our feature is finished, we can hide the toolpath from view and collapse the feature with the following steps.
In the CAM Tree, right-click Feature Lathe End Face, and click Blank/Unblank Toolpath.
Click the arrow sign next to the feature to collapse it.
In the File menu, click Save.
Part 4) Create a Turning Feature - OD Turning
Now we create a turning feature to rough and finish the outside diameter (OD) of the part. Note that we are splitting the front and back half of the part, so the front half is machined on the main spindle and the back half is machined on the sub spindle.
Right-click Machine Setup - 1, point to Turn Features, and click LatheTurning.
Click the Select Geometry button to hide the wizard and show the graphics area.
On the Layers tab of Layer-UCS-Post Manager, right-click the layer name Front Turn, and click Show.
In the Quick Selection group, of the Home ribbon, click
Pick By Layer.
In the Select Layer dialog box, click Front Turn, and click OK.
. - Click Next>> to go to the Patterns page.
- In the Undercut group, select the Remove Primary Undercut option.
This will force it to ignore the groove geometry to allow us to handle that with a separate feature.+ - Click Next>>
Define the Machining Strategy and Posting Settings
Under Template, click Rough / Finish.
The Current Operations list now displays one Turn Rough operation and one Turn Basic Finish operation. -
We don't need to open the Tool Crib this time, as the software already assigned the appropriate tool (80 Deg. 1/64 Rough).
Click Next>> to go to the Patterns.
- Set the System Compensation to On with Collision Detection, and select the Use Tool Holder option.
- Click Apply to All Operations.
Click Next>> to go to the Parameters.
Set the Depth of Cut to 0.040
In the Finish Allowance group, set Z to 0.0030
Click Next>> to go to the Rapids settings.
In the exit group, click the down arrow and select Rapid On Exit To Cycle Start X-Z.
This setting reduces the amount of tool movement between operations, as it returns to the cycle start instead of the home position defined for the tool. Note that this option moves in X first and then in Z as shown in the wizard image. -
Click Next>> to go to the Leads settings and make the following changes:
Set the Lead-in to Custom, and set Lead-in Z to 0.100
Set the Lead-out to Custom, and set Lead-out X to 0.100
On the lower-left, click Apply to All Operations so that the finish operation uses the same leads settings.
Define the Finish Operation Parameters
In this part of the example, we show an important tip for tool assignment in Mill Tun jobs. We are using the same turning tool to rough and finish the part as this reduces the number of tools that we need to mount on the machine. Next, we change the tool assignment for the finish operation to use the rough tool.
In the tree on the left, under Basic Finish, click
Finish. -
Note: At the bottom of the device tree, notice there is a tool under the Loose tools category. This is the tool that the system automatically assigned because our tool crib (lower turret) does not contain any lathe finish tools. Next, we change this operation to use a tool from the rough category.
On the lower-left under Tool Category, click Lathe Rough.
Tip: You can select a category under Tool Category to filter the tools list to show only tools from that category, which makes it easier to locate the appropriate tool. This is extremely helpful when there are a lot of tools in the job.
Click to select the only tool in the tools list, 80 Deg. 1/64 Rough Turning.
Click OK. -
You can go to the Leads settings and confirm that they are already set from using Apply to All Operations earlier (this step is optional).
In the quick access toolbar, of the CAM Tree Manager, click
In the information and analysis tabs on the right, click the Move List tab to show it.
At the top of the list, click Op. 2: Turn Rough-80 Deg 1/64 Rough Turning to advance the simulation to the start of the rough turning operation.
Tip: In the Move List tab of the simulation window, you can click the operations in the list to go directly to the start of the selected operation.
Click the
Run
As shown earlier, we can hide the turning geometry and hide the toolpath from view with the following steps.
In the Layers Manager, right-click Front Turn, and click Hide.
In the CAM Tree, right-click the second Feature Lathe Turning, and click Blank/Unblank Toolpath.
You can also click the small arrow next to the feature to collapse it.
Save.
Part 5) Create a Lathe Hole Feature
Right-click Machine Setup - 1, point to Turn Features, and click LatheHole.
Click Select Geometry.
Next we utilize a view option that helps us select a surface edge that is inside of the model. -
Press the S key, to turn off the Shaded view.
Click to select the surface edge (at the bottom of the front hole) as shown next.
This selects the depth point for our feature and automatically sets the Total Depth from the selected geometry.
The point is added to the Selected Geometry list. -
Click OK.
- Click Next>> to go to the Feature Settings.
Define the Feature, Machining Strategy and Posting Settings
Notice that our Total Depth of 1.7747 is automatically set from our geometry selection.
Under Feature Parameters, change the Diameter value to 0.500.
Under Parameters and Hole Type, click Blind. -
Click Next>> to go to the Machining Strategy.
Under Template,
click Hole.
Under Current Operations, with Lathe Center Drill selected, and click
(Delete Operation).
The Current Operations list now contains one Lathe Drill operation. -
Click Tool Crib and confirm that the 1/2 Drill tool is selected under Station #19 (the third station of the lower turret).
Click OK to close the Tool Crib, and click Next>> to go to the Parameters.
Under Cycle Type, click Peck.
No other changes are needed for this operation. Click Compute to create the toolpath.
You can turn the Shaded view back on by pressing the S key. You can also press the T key to turn on the transparent view and make it easier to view the toolpath inside the part. (Note then when using keyboard shortcuts, you may need to click anywhere in the graphics area first to give it key focus.)
Simulate the feature using the steps explained earlier to confirm the desired result.
Close the simulation.
You can now hide the toolpath and collapse the feature as explained earlier.
Part 6) Change the Default Submachine
The next three features that we create use the UT_MS (upper turret, main spindle) submachine, so we want to change the default submachine again. Changing the submachine this time is slightly different than the first time as features already exist, so we are prompted to confirm which features we want to change.
Under Machine Setup - 1, right-click the current submachine name (LT_MS), and click Edit.
Under Submachine Name, click the down arrow, and select UT_MS.
Click OK to update the default submachine.
A message displays to ask whether or not we want to change the submachine in existing features. We only want to change the default submachine for new features, so we click No.
All new machining features we create under Machine Setup - 1 now use the new submachine. The submachine can always be changed in the Posting page of the wizard.
Part 7) Create a Turning Feature - OD Grooving
Our next feature cuts a groove on the OD of the part. This is the last operation that we perform using the main spindle, before creating our part transfer to the sub spindle. We create our grooving operation first and then edit the feature to add our part transfer using MDI (manual data input).
Right-click Machine Setup - 1, point to Turn Features, and click Lathe Groove.
In the Layers Manager, right-click Groove, and click Show.
Right-click the CAD layer and click Hide to hide the model.
Click and drag to select the groove geometry in the graphics area.
Click
to confirm the selection. -
Click Next>> twice to go to the Machining Strategy.
Under Template, leave Groove Rough selected.
Notice in the Current Operations group, we only have a Groove Rough operation. -
Change the Posting Parameters to Canned Cycles.
Again, we can see the appropriate tool (1/8 OD Groove) is already assigned. You can open the Tool Crib to confirm the appropriate settings for the tool if desired.
- In the Pattern group, select Single Pass.
Since the tool is the same width as the groove we are trying to accomplish, a single pass is all we need. - Click Next>>
Under Parameters, set the X value of the Finish Allowance to 0.000.
Because we are using a single operation to
cut the groove, we remove the allowances.
The leads will be left as they are.
Click Compute.
(You can show the CAD layer and hide the Groove layer as well.)
Simulate the feature, hide the toolpath, and collapse the feature.
Part 8) Create a Mill 2 Axis Feature - Face/Z-axis Milling
The next feature that we create cuts the hex on the front of the part using a single operation to remove the material that remains after our turning operation. Again, we alter the tool assignment so that we can use a finish tool with a rough operation type. (This is done for illustrative purposes, as otherwise you could use a profile finish operation to accomplish the same task.)
Right-click Machine Setup - 1, point to Mill Features, and click Mill 2 Axis.
The FeatureGeometry Picking dialog appears with the focus on the Selected Geometry list to allow you to select geometry for the feature. -
Point to the surface at the bottom of the hex so that the surface edge highlights.
Right-click the edge (while it is highlighted) and click Constant Z to select a loop.
Defining the Chain Start Point and Direction of the Feature
In the Profile Chains list, select Chain-1.
The Chain highlights in the graphics area and the start point and the direction of the chain are shown as an arrow.
Next to the Profile Chains list, click
(Reverse Direction) to
reverse the direction of the chain.
Defining the Top of Feature and Total Depth of the Feature
Next we use the pick buttons to update the Top of Feature and Total Depth values for the feature.
Under the Feature Parameters, in the Top of Feature group, click in the Pick Top list to give it focus.
Click on the top of the edge of the model to set that as the top of the feature.
Selecting Top Edge |
Top Edge Selected |
The Top
of Feature updates along with the preview, and focus is shifted
to the Pick Bottom list
of the Total Depth group.
Click any edge of the surface under the hex.
The Total Depth updates along with the preview. -
In the graphics area, right-click and select
OK,
or in the Feature Geometry Picking dialog, select OK
to confirm the selections.
The Feature Geometry Picking dialog disappears and the Mill 2 Axis Wizard returns on the Geometry Selection page.
Click Next>> twice to go to the Machining Strategy page.
Define the Machining Strategy, and Posting Settings
The default template, Profiling, doesn't need changed, but we remove our finish operation.
Under Current Operations, click to select Profile Finish, and click
(Delete Operation).
Click Next>> twice to go to the Posting settings. (We are not using Tabs.)
Under Posting Mode, click Polar Interpolation.
Tip: Polar Interpolation is a mode in which the code is posted using XYZ coordinates that are then converted by the machine controller to XZC coordinates. This setting can be used to create more accurate machining and superior surface finishes compared to longhand code, but the machine controller must support Polar Interpolation and be configured to use it.
Click Next>> twice to go to the Tool settings. (We do not change the Multiaxis Posting settings).
Define the Profile Rough Operation Parameters
The following tool assignment is another example of changing tool categories to select a tool that is not the same as the operation type (finish tool for a rough operation type). The software already assigned an appropriate tool for the operation, but it selected a tool from the rough category and added it to the Loose tools. The tool that was already loaded in the Tool Crib is a finish tool, and we want to select this tool as we have already mounted it.
Click Tool Crib.
Under Tool Category, click Endmill Finish to filter the tools list.
Click to select the only tool in the tools list, 1/2 Flat Endmill - Long, and click OK.
On the left under Profile Rough, click Parameters.
Change the Side Allowance value to 0.000, because we are only using a single operation.
Click Next>> to go to the Leads settings.
Under Lead-in, click Blend. (Notice that our lead-out is also set to use the same settings.) -
Click Compute.
It is suggested that you simulate the program after each feature you create. This makes it much easier to find mistakes and resolve them immediately.
On the Other toolbar, click the
Simulation button.
Confirm that no changes are needed by running the simulation. Note again that you can use the Move List to go directly to the operation you are verifying.
You can also use the Report tab to check for any reported collisions during the simulation. Note that when you click an operation in the Move List (called manual navigation), no collision detection is performed for the operations that were skipped and a warning message displays in the Report tab.
Hide the toolpath and collapse the feature.
Part 9) Create a Mill Drill Hole Feature - Face/Z-axis Drilling
Next we create a Mill Drill Hole feature to drill the circular hole pattern on the face of the model. For Mill Turn jobs, this is called face or standard drilling (the tool is parallel to the Z-axis).
Right-click Machine Setup - 1, point to Mill Features, and click Mill Drill Hole.
Notice in the Hole Selection Manager that the default drilling type is Standard Drill, which is used for drilling along the Z-axis. Be sure to select the appropriate drilling type before confirming your geometry selections.
Click to select the six cylindrical surfaces of the holes as shown next.
Click
(OK), to confirm
the selection.
Tip: Selecting cylindrical surfaces allows the software to automatically detect and set the Feature parameters in the wizard for you.
In the Holes list, click to select the only hole item (0.25 Diameter).
Under Geometry Parameters, click to clear the Through Hole check box, because these holes do not go through the entire model.
Notice that our Diameter and Depth are automatically set to the correct values.
Click Next>> to update the wizard tree.
In the Feature page, we can see that the software automatically set the Diameter, Top of Feature, and Total Depth because we selected cylindrical surfaces. The software also automatically creates Hole Groups for all holes with these same feature parameters. This feature results in a single hole group.
Click the Group Retracts button, you can see that the Clearance Plane Height value is automatically set based on our geometry selection, clearance settings, and machining origin (work offset) position. (Click OK to close the dialog box.)
The Group Retracts determine the rapid movement to clearance between hole groups, not within them. For our rapid movement between holes, we use the Rapid Plane. For this model, we need to increase our rapid plane to clear the boss in the center of the model.
To position the turret out of the way for our transfer, set the Type to Cylinder, and the Radius value to 10.000.
(Click OK to
Change the Rapid Plane value to 0.7500.
Under Hole Groups, click anywhere in the row of Group 1 to select it and display the hole groups preview directly inside the wizard.
Tip: To modify the viewing orientation of the hole groups preview, click and drag to rotate the view (left or middle mouse button). To pan the view, hold Ctrl and drag with the middle mouse button. Use the middle mouse button (roll forward or backward) to zoom in or out.
The Hole Groups preview is very helpful in confirming the proper selections and feature parameters. Again, more information is available in this help system.
Under Template, click Hole.
Under Current
Operations, click to select Center
Drill, and click
(Delete
Operation).
Under Posting Mode, click Longhand Code.
This posting mode uses C-axis motion to drill the holes, as compared to the Auto/Y Axis Mode which uses Y-axis movement to drill the holes. If the submachine does not have Y-axis capability, Auto/Y Axis Mode and Longhand Code produce the same result.
Click Tool Crib and confirm the appropriate tool (1/4 Drill) is automatically assigned.
Click OK. -
Notice the Hole Groups list here, when changing the parameters for hole groups, it is important that you select a group in the list before changing any settings. For this example, we use the default parameters. -
Click Compute.
Part 10) Create a Part Transfer Using MDI (Manual Data Input)
For Mill Turn jobs, the MDI page of the wizard allows you to manually define machine movements by combining commands to create lines of code. This is used to handle machine axes movements that do not have a specific operation, such as part transfers, cutoff/transfer, parts catchers, steady rests, and tailstocks. We define our part transfer after the grooving operation as it is the last operation we perform on the main spindle before transferring the part to the sub spindle. Be sure to have your chuck jaws oriented properly in your machine definition. For more information on the chuck configuration, see The Chuck Configuration topic.
Note: You can create your own generic MDI files (templates) that are customized for your machine to handle transferring the part from the main spindle to the sub spindle. The expected workflow is to define a process once using MDI, save it to a file, then simply load the saved file and change a few values as needed per job. We do the same for this example using the generic part transfer MDI file that is installed with the software. Contact Support for assistance with MDI features: [email protected] / (727) 489-0003
In the CAM Tree, right-click the last Feature Mill Hole-Blind - 0.2500 feature (that we just created), and click Edit.
The Lathe Wizard displays for you to make changes to the feature. -
In the tree on the left, click MDI.
Notice the Save/Load group under the Task List. Click the
(Load) button.
The Open dialog box should display with the correct location already selected: C:\BobCAD-CAM Data\**Current Version**\Features. If not, navigate to this folder.
Click to select GenericPartTransfer.bcmdi and click Open. (Alternatively, you can double-click the file name to open it.)
The Load MDI Task dialog box displays. This dialog box allows you define exactly what tasks are overwritten with the information from the file. This allows you to load individual tasks from the saved file, but for this example, we use the full replace.
Click OK to replace the entire current Task List with the information stored in the file.
You can see that only the After Operation task contains any commands (it has the plus sign icon). Click the plus sign to expand the After Operation folder and view all the lines that are already defined. All of our commands are under the After Operation task, because our part transfer happens after the grooving operation.
We don't need to make any changes to our generic MDI parameters, but a few of the important commands that you may adjust per job are listed next. This is shown in the video as well as how to modify the values for a command.
Important Command Values:
Command |
Value |
Orient Main Spindle |
Angle |
Orient Sub Spindle |
Angle |
Move Sub Spindle to Clearance |
Axis |
Start Fast Feed Up to Part |
Axis and Feedrate |
Feed to Pickup Location |
Axis and Feedrate |
Part Transfer |
Part Pickup Position |
Send Sub Spindle Home |
Work Offset and Axis |
Note that the number of parameters that you need to adjust depends on the way you work. Many of these values may never be changed from the values defined in the MDI template file.
Tip: You modify commands on the MDI page using
the Parameters group. The general process is as follows:
• Expand a
Task
to view the Lines under it.
• Expand a
Line
to view the Commands under it.
• Click to select a
Command.
• All available parameters display
under Parameters at the bottom of the MDI page.
• Update the values as needed. (The
changes you make are reflected in the Task List.)
Click Finish to update the feature with the MDI part transfer.
Our part transfer is now output in the code, and is also visible in simulation (without MDI, in simulation the part just switches spindles without showing the transfer movement).
Simulate the program to view the part transfer.
Part 11) Change the Default Submachine for Machine Setup 2
Now that the part is transferred to the sub spindle, all of our machining features for the second half of the part are created under Machine Setup 2, which is set to Work Offset 2. Most of the remaining features use the UT_SS (upper turret, sub spindle) submachine, so we set the default submachine for creating features under Machine Setup 2.
Expand Machine Setup - 2 (if needed), right-click the current submachine name UT_MS, and click Edit.
Change the Submachine to UT_SS (upper turret, sub spindle), and click OK.
You can also collapse Machine Setup 1 to minimize the CAM Tree and reduce the need for scrolling.
Part 12) Create a Turning Feature - Lathe End Face
Machine Setup 2
Next we begin to create features under Machine Setup 2 to machine the back half of the part. If you would like to learn how to define this machine setup, view the Mill Turn Job Setup Example.
Change the View
In the document toolbar, point to Views, and click ISO 3.
This is the main viewing orientation we use while creating the features for the back of the part. (In the video, you can see that the instructor created custom shortcut keys to make using this view easier.)
Right-click Machine Setup - 2, point to Turn Features, and click Lathe End Face.
- Click Next>> twice to go to the Machining Strategy.
The Feature page of the wizard displays the stock settings that were automatically detected and set based on our stock geometry and work offset (machining origin) location from the Stock Wizard and Machine Setup. The software uses these values to determine the location of the first cut, and because they are automatically set, we do not need to modify these values for this feature.
The default template, Rough, doesn't need changed, and we do not need a finish operation. We simply use the roughing operation to cut the face to its final depth. -
- Click Next>> to go to the Tool page.
Define the Face Rough Operation Parameters
Confirm that the 55 Deg. 1/32 Rough Turning tool is selected under Tool Data. (As always, you can open the Tool Crib to confirm the proper tool selection and mounting).
The following image shows the tool we select (it is highlighted with the yellow holder). You can see that the tool is mounted with the correct orientation for machining the back side of the part (on the sub spindle).
Set the Depth of Cut to 0.0350
- Set the Z, and X values in the Finish Allowance group to 0.000.
Click Compute.
Simulate the feature and confirm that no changes are needed.
Part 13) Create a Turning Feature - OD Turning
The next feature is created to rough and finish the remaining stock material on the back half of the part.
Right-click Machine Setup - 2, point to Turn Features, and click Lathe Turning.
Show the layer Back Turn.
Pick By Layer.
In the Select Layer dialog box, click Back Turn, and click OK.
Under Template, select Rough / Finish selected.
Confirm that the 55 Deg. 1/32 Rough tool is selected under Tool Data.
Click Next>>.
- In the Compensation group, set the System Compensation to On with Collision Detection, and select Use Tool Holder.
- Click the Apply to All Operations button.
Click Next>>.
In the Finish Allowance group, set the Z value to 0.0030
Click Next>> twice to go to the Leads settings and make the following changes.
Set the Lead-out to Custom, and set Lead-out Z to -0.0500
Note: Notice that we used a negative lead-out, which creates an overlap in the toolpath where the front turning operation and back turning operation meet. (The toolpath extends past the selected geometry.)
Under Turn Basic Finish, click Finish.
Click Tool Crib.
Under Tool Category, click Lathe Rough.
Click to select the 55 Deg. 1/32 Rough Turning tool in the tool list, and click OK.
Click Compute.
Simulate the program and confirm the desired result.
Hide the toolpath, collapse the feature, and save the file.
Part 14) Create a Lathe Hole Feature
The next feature drills a large hole in the back of the part to prepare it for the boring operation we create afterward. Our drill for this operation is on the lower turret, so this feature provides an example of changing the submachine for the feature using the Posting page. (This is the only feature under Machine Setup 2 that doesn't use the UT_SS submachine.)
Right-click Machine Setup - 2, point to Turn Features, and click Lathe Hole.
Press S to turn off the Shaded view, and click to select the surface edge as shown next.
The wizard returns when you click the edge. -
Click Next>>.
Define the Feature Machining Strategy and Posting Settings
Notice that our Total Depth is automatically set (2.000) from our geometry selection.
Update the Diameter value to 1.2500.
Under Hole Type, ensure Blind is selected.
Click Next>>.
Delete the Lathe Center Drill operation from the Current Operations list. -
Click Next>>.
Change the Submachine to LT_SS (lower turret, sub spindle).
Click Tool Crib.
Confirm that the 1.250 Dia. 118 Deg. tool is selected, and click OK.
Click Next>>.
Click Compute.
Hide the toolpath and collapse the feature. You can also turn on the Shaded view. -
Simulate the feature.
Part 15) Create a Turning Feature - Boring
Important: When creating Turning features for boring, it is important that you select a boring tool (a tool from the boring category) in order to create proper simulation of the operation. (The boring tool type is handled differently in simulation.)
Hide the CAD layer and show the Back ID/Boring layer.
Click and drag a window to select the profile.
You can show the CAD layer, and then click
Click Next>>.
Under Feature Parameters, change the Feature Type to ID.
Click Next>>.
Set the Template to Rough / Finish , and click Next>> twice.
Click Tool Crib.
Under Tool Category, click Lathe Boring to filter the tools list.
Select the only tool in the tools list, 80 DEG 1/64 CRAD 3/4 INCH BORING BAR.
Click OK to assign the tool to the operation.
Click Next>>. - In the Compensation group, set the System Compensation to On with Collision Detection, and select Use Tool Holder. Click Next>>.
Update the Parameters as follows:
Set the Depth of Cut to 0.0400
Set the Z value in the Finish Allowance group to 0.0030
- Leave the X value alone
- In the Bounds group select the Trim To Stock option. This will force the toolpath to avoid the portion of stock already removed by our previous operations.
Click Next>> twice, and update the Leads settings as follows:
Set the Lead-out to Custom, and set Lead-out X to 0.0500
Under Turn Basic Finish, click Finish to go to the Tool settings.
Click Tool Crib.
Under Tool Category, click Lathe Boring.
Select 80 DEG 1/64 CRAD 3/4 INCH BORING BAR and click OK.
You can check the Leads settings of the finish operation to confirm that they are the same as the rough. -
Click Compute.
Hide the toolpath, collapse the feature, and simulate the feature.
Part 15) Create a Mill Hole Feature - Cross Drilling
For the final operation, we create a drilling feature to handle the cross drilled holes in the model. Cross (or radial) drilling means that the tool axis crosses the center line of the part (the tool is parallel to the X-axis). What is important here is selecting the drilling type, Cross Drill, in the Hole Selection Manager.
Right-click Machine Setup - 2, point to Mill Features, and click Mill Drill Hole.
In the Hole Selection Manager, next to Standard Drill, click the down arrow and select Cross Drill.
Important: When selecting geometry for Mill Drill Hole features, it is important to select the proper drilling type based on the orientation of the holes, as the software filters your selections accordingly. (Standard Drilling is parallel to Z-axis, Cross Drilling is perpendicular to [and intersects or crosses] the selected Rotation Axis, and Multiaxis Drilling is any orientation.)
Click to select the six cylindrical surfaces of the holes on the outside diameter of the part.
Click
(OK), to confirm
the selection. -
Under Material Approach, click Group Retracts.
Notice that our clearance Type is automatically set to Cylinder and the Radius value is 1.8500. The software automatically selects a cylindrical clearance for cross drilling and sets the Radius value based on the stock and clearance settings from the Stock Wizard and Machine Setup. (Note that the Group Retracts handle the clearance movement between hole groups and not within them. The Rapid Plane determines the rapid clearance movement within hole groups.)
Click OK.
Under Hole Groups, click anywhere in the row of Group 1 to select it and display the hole groups preview inside of the wizard.
Notice the Diameter, Top of Feature, and Feature Depth values are all automatically set because we selected cylindrical surfaces.
Click Next>>.
Select the Hole template, and delete the Center Drill operation from the Current Operations list.
Click Next>> to update the wizard tree with the new template.
Under Drill, click Drill to go to the Tool settings.
You can open the Tool Crib to confirm that the assigned tool is indeed mounted for cross drilling. It is important that you select a tool in the proper orientation for the operation you are creating.
Confirm that the 3/8 Drill tool is selected and click OK.
Click Compute.
Part 16) Final Simulation
Important: For Mill Turn Jobs, you cannot post or simulate the program unless all tools are mounted in the Tool Crib. For example, when the software cannot find the appropriate tool in the Tool Crib during tool assignment, it assigns a tool from the Tool Library and places it under the Loose tools item in the device tree. Loose tools are tools that are assigned to an operation, but not mounted. All Loose tools must be mounted before simulating or posting. You can open the Tool Crib to confirm there are no unmounted (Loose) tools before simulating or posting the program.
In the CAM Tree, right-click Mill Turn Tools, and click Tool Crib.
In the device tree on the left, drag the slider down to view the Loose tools and confirm there are none. Note that there is one Loose tools item per device, so be sure to check both (all) devices for Loose tools.
Tip: BobCAD-CAM uses a special convention for Loose (unmounted) tools. The Tool Number for loose tools is -1 (negative one). When you see a tool with a tool number of -1, you know that you need to mount it (or assign a different tool to the corresponding operation). The easiest way to see where a loose tool is assigned is to open the Assigned Tools dialog box (right-click Mill Turn Tools, and click Verify Tool Assignment). This dialog box lists all features to which each tool is assigned.
For our example, there are no loose tools, so we are ready to simulate the program.
Right-click Mill Turn Job, and click Simulation.
Part 17) Verify Tool Assignment and Tool Numbering
Mill Turn jobs contain three different methods for defining the tool numbering. The default method (Use Station #) automatically numbers the tools based on the station to which they are mounted. This is commonly used on machines that contain one or more turrets and is also adapted to work well for 5-axis applications in which the machine is equipped with a milling head. The second method (Use Tool ID) utilizes the Tool ID to guarantee a unique number is assigned to each tool. The final method (Manual) provides a completely user-defined or manual tool numbering scheme in which the software loads the tool number stored in the Tool Library, which you can modify as needed.
The following steps show you how to confirm proper tool numbering after creating all features for the job. (Note that you can also define your tool numbering while you create the job, as the same options are available in the Tool Crib.)
In the CAM Tree, right-click Mill Turn Tools, and click Verify Tool Assignment.
The Assigned Tools dialog box displays. This dialog box lists all tools that are actually used in the job (assigned to an operation) and lists various information about them.
Confirm the appropriate tool numbering for the job and make any changes as needed.
Note: The tool offset numbers for each operation are set in the Tool page of the CAM wizards. The BobCAD-CAM software always sets the offset numbers to match the tool number unless you use Override Offsets to define the offset number manually.
After confirming all tool numbering, click OK to close the dialog box.
Part 18) Post the Program
After simulating the program and confirming our tool numbering, no changes are needed so we are ready to post the program and create the NC program (G-Code).
Right-click Mill Turn Job, and click Post. (Alternatively, you can click Post and Save As if you would like to select a different location to which the file is saved. The default location is the BobCAD-CAM Data NC folder.)
The NC program displays in the Posting tab of the Layer-UCS-Post Manager. -
You can view the code from this location, and you can also right-click anywhere in the window to access another shortcut menu, for example, for opening the code in the Editor.
Save the file.
Congratulations! You have completed the Mill Turn Example 1 tutorial. Much more information about Mill Turn jobs is available in this Help system.
