The Document Toolbar
This topic will describe the document toolbar, and explain the options found in it.
Document Toolbar
The Document Toolbar allows you to have the view options for the graphics area available to you no matter what ribbon is currently in use.
The Document Toolbar options
                                                     Select
	 Mode - enables selection mode. Select
                                                     Pan
	 - The Pan function is used to pan or move the current viewing position
	 in the graphics area. To perform the function, click Pan (the mouse
	 pointer changes to the pan icon), then click and drag the view to
	 the desired position, and then release the mouse button. To end the
	 function, click Pan
	 function, click Cancel (or press Esc). Cancel (or press Esc).
                                                     Rotate -
	  The Rotate function is used to rotate or change the viewing
	 angle (around the center of the current viewing position) in the graphics
	 area. To perform the function, click Rotate, and then click and drag
	 the mouse to change the view. To cancel the function, click Rotate -
	 the mouse to change the view. To cancel the function, click Cancel. Cancel.
                                                     Zoom
	 Window -  The Zoom Window command is used to drag
	 a window in the graphics area and have the selected area expanded
	 to the full window size. To perform the command, click Zoom Window,
	 drag a window in the graphics area, and then release the mouse to
	 zoom in on the selected area. Zoom
                                                     Fit
	 All - The Fit All function is used to change the view of the
	 graphics area so that all geometry can be seen. When you click Fit All, the function is performed. Fit
                                                     Zoom
	 Previous -   The Zoom Previous command returns
	 to the last view perspective used. Zoom
                                                         Shaded
		 - The Shaded function is used to toggle the view of solids/surfaces,
		 in the graphics area, between a surface view or wireframe view.
		 To perform the function, click Shaded. To return, click Shaded
		 a second time. Shaded
		 a second time. View
		 an example View
		 an example
                                                         Transparent
		 - The Transparent function is used to make solids/surfaces in
		 the graphics area appear transparent (or see through). To perform
		 the function, you click Transparent.
		 To return to the
		 default view, click Transparent again. Transparent
		 To return to the
  View
		 an example View
		 an example
                                                         Wireframe -
		 The Wireframe View command shows and hides the interior lines
		 of surfaces and solids. Wireframe -
                                                         Blank
		 - The Blank function is used to hide selected geometry from view, and to prevent that geometry from being affected by any other functions.
		 To set entities to a blank state, click Blank, select geometry in the graphics
		 area to add them to the Selected Geometry list, and click OK. The geometry is hidden from view will not be affected by any other functions.
		 To reverse this state, use Unblank. Blank
                                                         Unblank
		 - The Unblank function is used to remove the blanked state from entities which have previously had that state applied to them using the Blank function. To perform the function, click
		 Unblank, select the geometry from the list of blanked entities which should have that state removed, and click OK. Unblank
 Hide All Images -
		 The Hide All Images function is used to hide any imported
		 images (in the graphics area) from view. This function is only
		 available in the View menu. To show the images, click Hide All
		 Images a second time. This function is used with BobART. Hide All Images -
 Hide
		 All Emboss Model - The Hide All Emboss Model
		 function is used to hide embossed geometry that is created using
		 BobART. This allows you to view any geometry that is hidden by
		 the model so it can be selected for other features. To view the
		 model again, click Hide All Emboss Model a second time. Hide
 Ortho Projection - The
		 Ortho Projection function is used to change the view in the graphics
		 area between the default perspective view and an orthogonal view. To perform the function, you
		 click Ortho Projection; to return to the default view, click Ortho
		 Projection a second time. Ortho Projection - The
		 Projection a second time. View
		 an example View
		 an example
                                                         Antialiasing
		 - The Antialiasing function smooths the edges of geometry displayed in the graphics
		 area. This is only used to improve the appearance
		 of the geometry in the graphics area, for example, when using
		 Print Screen to create an image. Antialiasing
 Surface Normal - The Surface Normal function is used to
		 show or hide the surface normals of solids/surfaces in the graphics
		 area. This indicates the outward (positive) direction of solids/surfaces.
		 This function is important for creating Multiaxis features. The Reverse Surface Normal Function. Surface Normal - The Surface Normal function is used to
		 This function is important for creating Multiaxis features. The Reverse Surface Normal Function. View
		 an example View
		 an example
                                                         Shaded
		 Smooth - The Shading Smooth function is used to smooth
		 the appearance of solids/surfaces in the graphics area. This is
		 turned on by default. To turn the function off, click Shading
		 Smooth. To return to the
		 default view, click Shading Smooth again. Shaded
		 default view, click Shading Smooth again. View
		 an example View
		 an example
                                                         Polygon
		 Shaded - The Polygon Shaded function is the default view
		 used for solid/surface entities. They appear as a shaded solid/surface.
		 The Polygon Lines function is used to change this view to a triangle
		 mesh. Polygon
		 mesh. View
		 an example View
		 an example
                                                         Polygon
		 Lines - The Polygon Lines function is used to show the
		 triangle mesh of solid/surface entities in the graphics area.
		 When you click Polygon Lines, the view of the solid is updated.
		 To return to the shaded view, click Polygon Shaded. Polygon
		 To return to the shaded view, click Polygon Shaded. View
		 an example View
		 an example
