The Posting Manager
This topic will explain the Posting Manager, will show where to find the Posting Manager initially, and provide a link for the topic that shows how to relocate the Posting Manager.
The Posting Manager
The Posting Manager displays posted NC programs, and is located, by default, on the right side of the application, docked with the BobCAD Live Manager, the Layer Manager, and the UCS Manager. The location of the Posting Manager, however, can be adjusted to preference, as explained in the  Introduction to Docking Panes topic.
The Posting Managers Shortcut Menu
Right-clicking in the Posting Manager will give you access to:
  • Save As - launches the Save As dialog to allow you to save the code to the desired location.
  • Predator Editor - launches the NC code in Predator Editor. This option is only available if Predator Editor had been installed by previous versions of the software as this software has been phased out.
  • NC Editor - launches the NC code in the NC Editor.
  • Mach 3 - If a Mach 3 license is held through BobCAD-CAM, this will open the NC code directly in Mach 3.
Tip: Using Ctrl+F will allow you to use the find function in the posted code without the need for opening the code in an editor.
Posting NC Code
Post Processors
The Operation Tree
The Tool Tree
Getting to Know the User Interface
